Thread: Focus Enhancements CenterStage CS-HD Video Scaler Review |
Diamond Member Username: Ecoustics
Fairfax,
VA
Post Number: 176 Registered: Dec-03
| Posted on Wednesday, April 07, 2004 - 12:52 pm: |
Focus Enhancements CenterStage CS-HD Video Scaler You may not realize it, but just about every new DVD player and HDTV has a video scaler and/or de-interlacer already built into it. Essentially what it does is resize, reformat, convert, and enhance a video signal to make it look as sharp, clear and as lifelike as possible. Why do I need a scaler? You may be thinking, if my equipment already has this feature, why do I need to buy it again? The simple answer is -- some scalers (video processors) do a better job than others. If you notice jagged edges, overly blurred motion scenes, overlapping colors, jumpy lines or flicker then you have noticed problems, called video artifacts. These artifacts are more common in older analog TVs mainly because they display less lines of resolution. Today’s HDTVs are capable of being four times better, which fixes some problems while errors in digital video processing can cause others. What is a scaler & de-interlacer? The scaler uses algorithms and interpolation methods to enhance, up-convert, or down-convert video. A de-interlacer converts interlaced video to progressive scan. In technical terms, it combines sequential fields of alternating lines (interlaced) into one video frame (progressive), effectively doubling the resolution. The better the scaler/de-interlacer, the better and more true to life the video looks.
More technical explanations are available at the following sites: http://scanline.ca/deinterlacing/ http://members.aol.com/ajaynejr/viddoubl.htm http://www.100fps.com/ CS-HD Basics Now that I have given the background, I can better explain the features of the CS-HD. The CS-HD acts as central switcher connecting all of your video sources (DVD, Cable, Satellite, VCR) to your display device (TV, Projector or Computer Monitor). It will accept the following inputs: two composite video, two S-video, two- component, one progressive component, and a RGB pass-thru. It has two outputs: DVI and RGB (VGA). Double the lines The CS-HD converts/scales a regular TV signal, commonly referred to as 480i (480 lines of resolution - interlaced) or a progressive scan 480p signal into HDTV quality formats (720p, 1080i, and even 1080p). The video up-conversion more than doubles the lines of resolution by using proprietary computer calculations. Does it work? Ultimately, you want to know -- will the CS-HD make my picture better? Unfortunately, there is no simple answer to this question. It depends on the equipment you already have. I was hoping for a dramatic improvement, but what I noticed was a subtle improvement on some displays more than others. I tested the CS-HD on three video displays, which included a 42-inch Plasma EDTV (852x480), a budget projector (964x544), and a rear projection (CRT) HDTV (1080i). Ideally, I would have liked to do side-by-side comparisons with and without the CS-HD, but I had to rely on my memory for all results. Better front projection The most noticeable improvements were recognized by up-converting 480i to 720p or 1080i. The projector yielded the best results. The Plasma EDTV showed the least improvement mainly because the CS-HD isn’t optimized or used to its full potential and it does not support 852x480p output resolution. VCRs opted out The CS-HD will most effectively improve 480i video from Cable or Satellite TV, as well as older DVD players. Regrettably, it does not work well with most low cost VCRs. VHS tapes tested showed jumping frames, because the CS-HD lacks a time based correction feature needed to work properly. However, higher-end VCRs may have the feature built-in, which should make it compatible with the CS-HD. Making it work Usability wasn’t quite what I had expected. The output setting is set once to the highest resolution of your display, but each input setting has to be manually selected whenever you switch video sources. A basic remote control and onscreen menu make things a little easier. However, get ready to macro program your universal remote, or your significant other or kids will be yelling at you when they can’t watch a DVD. Cost factor The CS-HD is considered a budget video scaler at $995, and is the least expensive in the Focus Enhancement’s line of video processors, which includes the CS-1 ($1,995) and CS-2 ($2,495). The CS-HD is more affordable but lacks key features found in the higher end models, such as DVI inputs and outputs (with HDCP), user definable output resolutions, time-based correction, and user upgradeable firmware. Test it out The bottom line is, try out the CS-HD if you desire better video performance. Hopefully, your local dealer can arrange a product loan before you make a purchase or can come to your home to set it up. If it makes a noticeable improvement with your system, then you can easily justify the cost. Pros Accepts many video sources Converts 480i to HDTV Compatible with computer monitors or TVs Cons No DVI inputs No time-based correction Cumbersome video switching Limited output resolutions Manufacturer Links: http://www.focusinfo.com/products/centerstage/centerstage.htm http://www.focusinfo.com/company/pr_new/090103_CES.htm http://www.focusinfo.com/ Test equipment: Studio Experience Matinee 1HD Projector Zenith P42W34 42-inch Plasma EDTV Zenith R40W26 40-inch Rear Projection CRT HDTV Zenith DVB317 DVD Player LG LSS-3200A DirecTV HDTV Receiver BetterCables.com Cables
More Reviews: CS-HD reviews All scaler reviews Remember I am just one man with one opinion. If you own this product, or have a comment or question feel free to add your thoughts below. Brian Mitchell Founder & CEO eCoustics.com |
Relevant Product Info
| Posted on Tuesday, July 06, 2004 - 01:15 pm: |
i have an hitachi 60v500 lcd 60" and a denon 2200 dvd player no cable or sattalite im a little confused on what this video scaler is and if its something that will improve my picture it looks to me like it just turns it into progressive scan and i already have that |
Unregistered guest |
| Posted on Wednesday, February 09, 2005 - 04:02 pm: |
I'm considering getting a Sharp "Aquos" series 45" LCD flat panel HDTV/monitor. It's capable of very hi-res displays, up to 1080p. I'm sure DVDs and HDTV will look fine, but I'm concerned about regular non-HD TV. Will this scaler make a significant improvement? I don't expect it to be as good as HD, but regular TV seen on a large monitor without scaling or up-converting is ususally pretty mediocre! |
New member Username: Fraser55555
Farmington,
GA
Post Number: 1 Registered: Jul-05
| Posted on Sunday, July 17, 2005 - 09:16 pm: |
I had hoped for a professional response to my, quite simple problem, but maybe you guys know anyway. My Echostar receiver formats satellite pictures (including hi-def) just fine. When I plug CMP video from my DVD into the same display, I get short fat people. Please recommend an appropriate scaler---nothing too fancy! Thanks -----Donald Kerr
