Thread: DVD-Audio |
Silver Member Username: John_a
Post Number: 522 Registered: Dec-03
| Posted on Wednesday, April 07, 2004 - 05:41 am: |
To anyone who values sound quality, and who wishes to use a DVD player for music, such as playing CDs. Ensure that any new DVD player you buy is capable of playing DVD-Audio. DVD-Audio, also known as "DVD-A", is, today, the absolute top of the pile for sound quality. Every DVD-Audio player will also play DVD-Video ("DVD-V") discs and CDs. Every DVD-Audio disc has DVD-Video tracks, too. So you can already play any DVD-Audio disc, and get excellent sound, on any DVD player. Try one, and see. But a DVD-Audio disc played on a DVD-Audio player gives more than excellent sound, it gives fantastic sound. DVD-Audio renders CD obsolete for sound quality. DVD-Audio is a 5.1 surround format. In addition, most DVD-Audio discs also carry a stereo (2.0) version of the same material. For technical background, and more information, one clear, accurate summary is from a UK disc manufacturer:- DVD-Audio Introduction I am an audio and home cinema/theater enthusiast, with no competing interest, commercial or otherwise, nor any connection with any relevant commercial organisation. |
Relevant Product Info
Silver Member Username: Myrantz
Post Number: 117 Registered: Feb-04
| Posted on Thursday, April 08, 2004 - 03:30 am: |
"Every DVD-Audio disc has DVD-Video tracks, too." John A - an error perhaps?
Post Number: 118 Registered: Feb-04
| Posted on Thursday, April 08, 2004 - 03:34 am: |
"Every DVD-Audio disc has DVD-Video tracks, too." John A Is this an error or if not, does this mean you can play DVD-A on an ordinary player and just keep the video signal off? |
Post Number: 119 Registered: Feb-04
| Posted on Thursday, April 08, 2004 - 03:36 am: |
John A - what a mess! Please ignore first post. |
Post Number: 546 Registered: Dec-03
| Posted on Thursday, April 08, 2004 - 05:02 am: |
My Rantz, Thanks. But this proves my point! Even an audio connoiseur like you gets mixed up. The terminology is a total mess. Anyone with any sort of DVD player should just try any DVD-Audio disc. It will play. It will sound wonderful. It is that simple! |
Post Number: 120 Registered: Feb-04
| Posted on Thursday, April 08, 2004 - 09:00 am: |
Sorry John, I am a little confused by your statement. I get the point that DVD-A will play on ordinary players but when you say DVD-A has video tracks - don't you mean audio tracks? |
Post Number: 548 Registered: Dec-03
| Posted on Thursday, April 08, 2004 - 10:39 am: |
My Rantz, Yes, I was unclear. I wrote "Every DVD-Audio disc has DVD-Video tracks" ...by which I meant "Every DVD-Audio disc has audio in DVD-Video format, and well as in DVD-Audio format". That is to say, all DVD-A discs, besides the DVD-A format audio, have the same material either Dolby Digital or DTS, usually both. Thanks!
Post Number: 123 Registered: Feb-04
| Posted on Thursday, April 08, 2004 - 03:27 pm: |
John A Most times I write here is when I should be sleeping! Insomnia - good movie - but a bad thing! |
Bronze Member Username: Black_math
Post Number: 49 Registered: Dec-03
| Posted on Wednesday, April 14, 2004 - 06:45 pm: |
OK, Here is a question. The Pioneer DVD-45A down-samples the digital out from 192kHz or 176.2kHz to 48kHz. Does every DVD-A player do that? If so, wouldn't it be advisible for people to use the 5.1 analog outputs for connection? I ask this because a lot of people opt to use 1 digital cable. |
Silver Member Username: Two_cents
| Posted on Wednesday, April 14, 2004 - 07:40 pm: |
Ben, You must use analog outputs for true DVD-A (and SACD). That means connecting 6 separate audio cables from the player to the receiver. |
Post Number: 633 Registered: Dec-03
| Posted on Wednesday, April 14, 2004 - 10:38 pm: |
That's right, Two Cents. Ben, my NAD T533 will do that, too, but you only get CD-quality sound that way. You would not choose it. I guess that option is there for people who do not have 5.1 analogue inputs on their amp/receiver. I guess you could get the real two-channel 192 kHz 24-bit DVD-A by feeding the signal to the CD analogue two-channel input. I haven't tried that. If it works, it should be a much better option than down-sampling. |
Silver Member Username: Gman
Mt. Pleasant,
SC
Post Number: 411 Registered: Dec-03
| Posted on Wednesday, April 14, 2004 - 11:59 pm: |
Two Cents-- generally true, except with the Pioneer Elite 49TXi that I have connected to my Pioneer Elite 59Avi universal player. It plays everything except video through a single firewire connection to the receiver. For video I connect the player to the TV component output. When I get a new HDTV with HDMI, I will connect that directly to the TV too. I guess I have to wait until Pioneer Elite makes a receiver with HDMI. What is also great about the firewire connection between the receiver and player is that it automatically "knows" what disc is in the tray and plays the appropriate format, unless you tell it otherwise. I put my "Last Waltz" DVD-A/cd stereo disc in the player last night and it automatically played the DVD-A. Then I presses the remote later and played it in cd stereo. Both formats are on the same side of this disc. |
Post Number: 636 Registered: Dec-03
| Posted on Thursday, April 15, 2004 - 12:28 am: |
I think Pioneer are leading the field in this. There is no technical reason why the DVD-A processor has to be in the player and not the receiver; it is to do with "format rights agreements" or similar. Although it has great bandwidth, maybe Firewire aka iLink is a legal loophole, not a technical necessity? |
