Thread: Rabbit ears - Question |
Bronze Member Username: Em69
Ottawa Canada
Post Number: 31 Registered: Mar-05
| Posted on Monday, September 12, 2005 - 08:13 am: |
I am running two TVs with one set of rabbit ears. But, one TV gets a few more channels than the other. Would a "booster" help to get the remaining missing channels? |
Gold Member Username: Dmwiley
Post Number: 1045 Registered: Feb-05
| Posted on Monday, September 12, 2005 - 08:52 am: |
Why buy a booster? As cheap as rabbit ears are get another set. |
Ottawa Canada
Post Number: 32 Registered: Mar-05
| Posted on Monday, September 12, 2005 - 11:41 am: |
The second TV is in the basement and the rabbit ears are on the main floor. Reception wouldn't be as good and I probably would have less channels. |
Post Number: 1056 Registered: Feb-05
| Posted on Monday, September 12, 2005 - 01:08 pm: |
Hard to say what boosting the signal would do-so many variables. You may be losing some signal due to distance. Before spending any money, might want to try connecting current rabbit ears directly to second tv just for comparison. |
Silver Member Username: Vindsl
Post Number: 259 Registered: Jul-04
| Posted on Monday, September 12, 2005 - 01:45 pm: |
Just get yourself a distribution amp, and life will be beautiful. I've run several of these things, over the years, and one is as good as another, IMHO. You don't need to spend a lot of money. Example: http://www.walmart.com/catalog/product.gsp?product_id=2625064 Basically, you plug 'em in and forget 'em...
