Thread: Warner Bable box V-format |
| Posted on Saturday, September 10, 2005 - 01:04 pm: |
I have 2 TV's hooked to Warner Digital (HD) cable boxes. I've used the componet V output on the cable boxes. My Pioneer Elite will not strech the 720i or 480 channels. My Mitsubisi Diamond strechs the channels but i get bars on the sides of the screen. I've been told i need a different model cable box, one that has a v-format feature. Is this true? what Warner box does this? LN |
Cable Hacker Unregistered guest |
| Posted on Saturday, September 10, 2005 - 04:41 pm: |
Im guessing your cable boxes aint hooked up to HD TV's so thats a reason why it will not fill up the screen usually the local HD Broadcast's dont fill up the screen it would be a square box but as for the movie channels it fills up but you still see the top and bottom bars, it has nothin to do with your cable box its your TV. |
| Posted on Saturday, September 10, 2005 - 08:42 pm: |
Cable Hacker, thanks...but both TV are top end HDTV's....... LN |
| Posted on Saturday, September 10, 2005 - 10:40 pm: |
your HDTV should have settings to change the display 4:3,auto etc. I still say it has nothin to do with your cable boxes. |
Silver Member Username: Cableguy
Deep in the ...
U.S.
Post Number: 320 Registered: Mar-05
| Posted on Monday, September 12, 2005 - 01:41 pm: |
what STB are you currently using?
