Thread: Archive through August 21, 2005 |
Silver Member Username: Maple_leaf
Post Number: 664 Registered: Apr-05
| Posted on Sunday, August 07, 2005 - 12:18 pm: |
fortec keys direction press menu.... right arrow 2 clicks... down arrow to code... press k... enter 1010 for password... down arrow to nagravision.. press k... right arrow over 11 times until u see dish network above... down arrow 1 time.. change the 2 zeros to 01.. down arrow to keys.. enter new keys .. press k to save.. exit out back to tv .. u good to go. On the remote... sat = A Info = B Red tv/audio = C Green/pause=D yello/audio = E blue/guide = F You can try this. |
| Posted on Sunday, August 07, 2005 - 12:24 pm: |
thank you maple leaf but i did that and it doesnt work plz help ibe been trying to get it to work sence yesterday thanx again. |
| Posted on Sunday, August 07, 2005 - 03:10 pm: |
hey guys can ne one help plz the new dishnework keys dont work i have a (fortec lifetime ultra)and i dont know y it dont work if you can help id be more then grateful. thanx |
| Posted on Sunday, August 07, 2005 - 03:58 pm: |
How to change Dishnet keys: 00 or 01 Pansat receivers................ press menu go down to parental controls, and press OK press down arrow and enter 0000 thats 4 zeros now go down to nagravision and press ok now press the right side arrow next to the ok button 11 times until it says dish network now press the down arrow 1 time key number should read 00 now now press the down arrow 1 time using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F) set the key to whatever the latest key code is 8A C4 96 93 EC 79 9D 57 ....(example only) now press the ok button! then press exit 3x to exit the menu Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats. ............................................................ Fortec key change method 1)With receiver hooked up to TV and satellite: 2)Press MENU on the remote control 3)Then right side arrow to CHANNEL EDIT 4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688) 5)Then right side arrow to turn OFF, KEYCODE FUNCTION 6)Go to NAGRAVISION and press OK 7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK)) 8)Go down to KEY Number, then right side arrow to set to "00". 9)Go down to Key Data and enter the latest KEY with your remote control. D5 6F BB 83 00 D8 B0 4E ...(example only) 10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number “00” is saved. 11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01 12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only) 13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number “01” is saved. 14)Press EXIT once. 15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT. 16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset Fortec buttons to use for letters Sat=a info=b tv/radio=c pause=d audio=e guide=f These are latest WORKING keys also: key0: A6 00 E2 C0 56 7E 4A 45 (active) key1: 88 7B D0 37 D9 BA 43 73
| Posted on Sunday, August 07, 2005 - 06:30 pm: |
hey thanks LK but before it would say scrambled or bad chanel but now it says data is being downlowded is that good or bad |
| Posted on Sunday, August 07, 2005 - 06:41 pm: |
thank you LK it works now thank u so much. |
New member Username: Poppaslim
Toronto,
Ontario
Post Number: 6 Registered: Aug-05
| Posted on Sunday, August 07, 2005 - 06:49 pm: |
any 1 down?
Toronto,
Ontario
Post Number: 7 Registered: Aug-05
| Posted on Sunday, August 07, 2005 - 07:41 pm: |
where do i dowload keymaster any1 plz help me out
| Posted on Sunday, August 07, 2005 - 07:56 pm: |
you can download keymaster at dsscentral .net |
New member Username: Chatau
Montreal,
Canada Qc
Post Number: 2 Registered: Aug-05
| Posted on Sunday, August 07, 2005 - 10:44 pm: |
Pliz Dish network new keys |
| Posted on Monday, August 08, 2005 - 12:17 am: |
DISHNET KEYS Current 08-05-05 7:25pm EST Key0: A6 00 E2 C0 56 7E 4A 45 ** Active Key1: 88 7B D0 37 D9 BA 43 73
Unregistered guest |
| Posted on Thursday, August 11, 2005 - 02:22 pm: |
what are todays keys |
Silver Member Username: Hamtec
Post Number: 232 Registered: Jun-04
| Posted on Thursday, August 11, 2005 - 02:26 pm: |
todays keys are: Key 1 DB 76 17 77 A1 CA 75 DC |
New member Username: Wbrhodie
Post Number: 1 Registered: Aug-05
| Posted on Thursday, August 11, 2005 - 02:29 pm: |
i would like key numbers for today August 11, 2005 |
Bronze Member Username: Poppaslim
Toronto,
Ontario
Post Number: 15 Registered: Aug-05
| Posted on Thursday, August 11, 2005 - 09:44 pm: |
DISHNET KEYS Current 08-11-05 1:35pm EST Key0: A6 00 E2 C0 56 7E 4A 45 Key1: DB 76 17 77 A1 CA 75 DC ** Active
| Posted on Thursday, August 11, 2005 - 09:53 pm: |
how do i change keys on coolsat4000pro |
| Posted on Friday, August 12, 2005 - 06:01 pm: |
did they change the keys again......???? I already have the ones for August 11 and they just stopped working a little while ago.... |
GOOOOLS Unregistered guest |
| Posted on Friday, August 12, 2005 - 06:16 pm: |
Yes, they changed the keys again today. When you have the new keyes, can you post them here? |
MarkSammarooo Unregistered guest |
| Posted on Friday, August 12, 2005 - 06:41 pm: |
Key0 D5 96 E1 CE C0 00 AD 0F ** Active 8/12/05 Key1 DB 76 17 77 A1 CA 75 DC |
New member Username: Ajbene
Post Number: 3 Registered: Jun-05
| Posted on Friday, August 12, 2005 - 07:54 pm: |
any new ones this is not working MarkSammarooo |
Bronze Member Username: Justme123
Post Number: 55 Registered: Mar-05
| Posted on Friday, August 12, 2005 - 08:14 pm: |
Change D5 to D6 |
Markenter Unregistered guest |
| Posted on Friday, August 12, 2005 - 08:16 pm: |
Dishnetwork Key 0 is active, changed FRI AUG 12th, 2005 KEY0:D6 96 E1 CE C0 00 AD 0F KEY1:DB 76 17 77 A1 CA 75 DC
| Posted on Friday, August 12, 2005 - 08:32 pm: |
MARKENTER THESE KEYS AREN'T WORKING |
| Posted on Friday, August 12, 2005 - 08:46 pm: |
how do i get parental control off?.... is there a way to reset the key to whatever I want?... the 4 digit one. thanks |
| Posted on Friday, August 12, 2005 - 08:53 pm: |
yeah reinstall the flash! |
RANTone Unregistered guest |
| Posted on Friday, August 12, 2005 - 09:03 pm: |
LK,do you have the latest keys? |
BusterPepsi Unregistered guest |
| Posted on Friday, August 12, 2005 - 09:17 pm: |
thanx for the new keys..Works great but does anyone know how to get hbo up and running? |
| Posted on Friday, August 12, 2005 - 11:07 pm: |
carlos78 Unregistered guest |
| Posted on Saturday, August 13, 2005 - 02:26 am: |
can any one please tell me the key that is working now |
New member Username: Madzibaba
Harare,
Harare
Zimbabwe
Post Number: 3 Registered: Aug-05
| Posted on Monday, August 15, 2005 - 01:03 pm: |
i am in zimbabwe which keys do i use is it pasnet or dish net |
Harare,
Harare
Zimbabwe
Post Number: 4 Registered: Aug-05
| Posted on Monday, August 15, 2005 - 01:25 pm: |
i want to access the pas10-c band can any one give me th codes send to apostleu@yahoo.com i have a fortec star reciver and i am in zimbabwe in southern africa |
| Posted on Monday, August 15, 2005 - 08:09 pm: |
| Posted on Monday, August 15, 2005 - 09:11 pm: |
what are the keys for today August 15th |
| Posted on Monday, August 15, 2005 - 09:13 pm: |
DISHNET KEYS Current 08-15-05 7:35pm EST Key0: D6 96 E1 CE C0 00 AD 0F Key1: 8D 11 96 22 A3 25 D7 04 ** Active |
SlickVicster Unregistered guest |
| Posted on Tuesday, August 16, 2005 - 10:33 pm: |
Will Fta outlast regular Dishnetworking programing? |
| Posted on Wednesday, August 17, 2005 - 11:49 am: |
just got a new vs2000 and trying to learn how to program have 2 eyes on dish need to know the best 2 satellites to aim at and what keys to use for that set of sat.s using the vs2000 would like to learn more on my own but looks like not much time left before everything gets zapped thanx |
Outlander05 Unregistered guest |
| Posted on Wednesday, August 17, 2005 - 08:48 pm: |
does anyone have the new keys? |
| Posted on Wednesday, August 17, 2005 - 08:49 pm: |
HEY66805354 Unregistered guest |
| Posted on Wednesday, August 17, 2005 - 10:30 pm: |
keys for August 17, 2005 00- E6 96 B2 OA 37 35 20 21 |
| Posted on Thursday, August 18, 2005 - 03:11 am: |
NEED HELP, I KEEP ON GETTING SCRAMBLED OR BAD CHANNEL ON ALL THE PPV CHANNELS. I HAVE THE MULTISTAR PANTEC ULTRA ANY SUGGESTIONS,THANKS |
New member Username: Robot
| Posted on Thursday, August 18, 2005 - 06:03 am: |
have viewsat vs2000 pointing at 110 and 119 does anyone have info on how to input new keys and what keys are needed? have looked at hundreds of posts but no info on vs2000 |
New member Username: Sharkguy
| Posted on Thursday, August 18, 2005 - 10:23 am: |
I have 3 MultiStar boxes, my program Guy has screwed me! The boxes work w/ key code but only 50-60 chans. max & most of them are pixeled, no good, or black.Can anyone help or are these boxes junk ?? Please email me @ Raceincguy@aol.com |
| Posted on Thursday, August 18, 2005 - 11:32 am: |
anybody know how I get autoroll 276 |
| Posted on Thursday, August 18, 2005 - 11:35 am: |
If some channels work fine,then the boxes work..need to do a new scan or add a new channel list then do a reboot/reset..U should get mote than 50 good channels now...most others will be srambled or black because many channels have either switched transponders within the 110 bird, and many have switched to nagra2...next month ALL channels will be scrambled or black screen when nagra2 is completed,if U're using Dishnet satellites 110-119.. |
| Posted on Thursday, August 18, 2005 - 01:35 pm: |
Key 00: E6 96 B2 0A 37 35 20 21 Key 01: C4 B1 B5 B5 DD 6E Af 81 Active.... |
New member Username: Artinusa
Post Number: 8 Registered: Jun-05
| Posted on Thursday, August 18, 2005 - 03:28 pm: |
thank you DYNAMO |
S.Smith Unregistered guest |
| Posted on Thursday, August 18, 2005 - 04:38 pm: |
LK - Do you know if there is, or will be any patches/fixes for the Fortec satilite system for the month of September and beyond? |
New member Username: Bobbyc
| Posted on Thursday, August 18, 2005 - 05:23 pm: |
LK, The same question as S.Smith? Thanks BC |
| Posted on Thursday, August 18, 2005 - 05:47 pm: |
?????...what are U asking?...U have working bins/fixes/patches now...use them...they don't ever go bad..but FTA and Dishnet will change to nagra 2 in September...then NO FREE TV..and if U didn't know that,then U shouldn't be in this hobby..and if U didn't know there was NO public hack now, then same goes there too.. BTW...Fortec, Pansat, Coo*lsat, Pantec, Viewsat, ...its all the same = Nagra2 |
| Posted on Thursday, August 18, 2005 - 07:47 pm: |
LK, Why are you getting mad? I ask you because I think that your answers are honest. Some of us are not " in this hobby" for anything more than just watching TV...when we can. We live in places that can't get cable and have to put up with Adelphis and their ever increasing prices. I thought this site was " to ask questions of persons, like yourself, that know of which you speak! I also know my TV is not free. I paid for equiptment and had to learn how to set it up and work...which it does. Thanks to people on this site I can keep it working at least for as long as it can. I don't know anything about " public hacks" but I do know that this is a public forum where I would think, people like me, ask questions of people like you who we would think are here to help? I'm sorry if our" dump" questions bother you. Bob |
| Posted on Thursday, August 18, 2005 - 08:00 pm: |
he gets mad when peeps ask lazy questions |
| Posted on Thursday, August 18, 2005 - 08:14 pm: |
well i guess it is getting closer to nagra 2 fewer and fewer chanels every day. what is the likelyhood that directv cards will again become ava. ya'll have a good one |
New member Username: Sat0lite
| Posted on Friday, August 19, 2005 - 12:25 am: |
would anyone happen to know why none of my ppv arent working?. if anyone knows please tell me . |
| Posted on Friday, August 19, 2005 - 03:48 am: |
LK said that there will be no free TV after Sep2 since dishnetwill move. My Pansat is just died, worth to buy another one? I would like to have an opinion from you guys here. Thanks. |
******B-I-R-D-eeeeeee****** Unregistered guest |
| Posted on Friday, August 19, 2005 - 08:31 am: |
-LK -iS A AZZ O...MABLE LEAF IS A SZZ O. U ALL ARE AZZ OOOOOOOOOOOOOOOOOOOOOOOOO. THERE ISZ NO HACK FOR NOTHING........... ANYONE SAYS THAT THERE IS A HACK OF ANYKIND IS A LYING DOG. I ONLY HAVE THE HACK.... I COLIN AND MC...SCREW U... |
| Posted on Friday, August 19, 2005 - 08:51 am: |
PPV channels have switched to Nagra2..I never stated Sept 2, exactly...I said NEXT month..NO don't buy anything now...common sense!..and dishnet is NOT moving, just using a new encrytion system (nagra2)which is not hacked in public or with FTA.. |
Post Number: 8 Registered: Aug-05
| Posted on Friday, August 19, 2005 - 09:28 am: |
LK, You again sound like the expert that you obviously are. Don't get down in the gutter with the jerks like the guy posted above you. Anyone with a brain and common sense knows what they are. Some of us just need help from experts, not mindless rambling. BC |
BLACKBAT Unregistered guest |
| Posted on Friday, August 19, 2005 - 10:39 am: |
-The only thing LK is a expert of is "CRYING and giving HEAD. |
white mouse Unregistered guest |
| Posted on Friday, August 19, 2005 - 10:42 am: |
Thanks LK, I really dont know much in this field, so, need your help and expertise. I wont buy anything now. |
| Posted on Friday, August 19, 2005 - 04:31 pm: |
LK, pls ignore those words. I respect your expertise. White Mouse |
| Posted on Friday, August 19, 2005 - 05:42 pm: |
super mex Unregistered guest |
| Posted on Friday, August 19, 2005 - 06:00 pm: |
0 E6 96 B2 0A 37 35 20 21 there they are enjoy |
bongocero Unregistered guest |
| Posted on Friday, August 19, 2005 - 06:13 pm: |
I just entered those numbers and still does'nt work, super mex. |
donaldjc Unregistered guest |
try Active Key0: D6 96 E1 CE C0 00 AD 0F Key1:DB 76 17 77 A1 CA 75 DC from the Key Master |
| Posted on Friday, August 19, 2005 - 06:39 pm: |
DISHNET KEYS Current 08-19-05 5:30pm EST Key0: CF 2B 37 83 17 B2 CC 87 ** Active Key1: C4 B1 B5 B5 DD 6E AF 81 |
supermex Unregistered guest |
| Posted on Friday, August 19, 2005 - 07:11 pm: |
sorry i copied wrong set......No joke sorry the ones above me are right..0 cf 2B is right.. |
| Posted on Friday, August 19, 2005 - 07:37 pm: |
donald..the keys U posted are NOT from Keymaster...those are keys U posted from GetKeys,which are incorrect!... The keys I posted above are correct and from Keymaster..Keymaster V2 always has the latest and correct keys..Download the file from dsscommunity. com File Share FTA area...Getkeys program is outdated and keys are always very late or incorrect |
New member Username: Iul13
Montreal,
Qc
| Posted on Friday, August 19, 2005 - 09:36 pm: |
sorry but movies chanel doesn't work |
Post Number: 731 Registered: Apr-05
| Posted on Friday, August 19, 2005 - 09:37 pm: |
That's because he's a mod don't you think.LMAO |
Post Number: 732 Registered: Apr-05
| Posted on Friday, August 19, 2005 - 09:39 pm: |
No LK I just found out from a couple of my friends that were called by Dishnet that the reason he posted the wrong keys is because he's a mod and trying to keep people from hacking Dish. |
Montreal,
Qc
| Posted on Friday, August 19, 2005 - 09:52 pm: |
soo what we have to do ? |
****B_I_R_Deeeee**** Unregistered guest |
| Posted on Friday, August 19, 2005 - 10:15 pm: |
-A Mable Leaf and LK WHY don't U two birds make like a bird a FLOCK OFF...(He-Ha-He-Ha)... two f_u_c_kin FOOLS. |
| Posted on Friday, August 19, 2005 - 10:35 pm: |
LK: my remote controller is dead, can I have any other way to input the "KEY", thanks. |
| Posted on Friday, August 19, 2005 - 10:39 pm: |
nope,not manually..can flash an autoroll bin that will input new keys |
White mouse Unregistered guest |
| Posted on Friday, August 19, 2005 - 10:46 pm: |
LK: Could you pls tell me how to do that? or my last option is to buy another remote controller? thanks a lot. |
| Posted on Friday, August 19, 2005 - 10:58 pm: |
Well LK they work on my receiver.Fortec Star Ultra I was using the set you put in and they stopped working. And started to work again with those numbers. |
| Posted on Friday, August 19, 2005 - 11:04 pm: |
donald...that makes absolutely NO sense!...and hard to believe....must be some magic thing...lol mouse...how to install autoroll is posted here everywhere...its simple..READ..2 minutes.. |
| Posted on Friday, August 19, 2005 - 11:07 pm: |
mouse..http://forum.ecoustics.com/bbs/messages/2/141416.html |
| Posted on Friday, August 19, 2005 - 11:10 pm: |
sorry LK, I have no knowledge in this field... |
| Posted on Friday, August 19, 2005 - 11:12 pm: |
thanks, LK... |
I don't do house calls...just read the link...it doesn't get any easier than this.. |
| Posted on Saturday, August 20, 2005 - 12:25 am: |
LK: I finally download the auto-roll file (v031205). Is it a lol (low level?) v245? I got lost with all these words here. But the big Q here is what should I do with this transfer it to the pansat 2500a through RS-232 port? Could you give me a procedure? or I can find the protocol somewhere? Please. I know I do not belong here...But I really appreciate your help and patience. |
| Posted on Saturday, August 20, 2005 - 12:41 am: |
Hi LK, I am getting there... is the below that whatI should do? 1. Flash your Pansat 2300 with latest X-7500 / Pansat 2500 with X-8500 bin file. (This MUST BE DONE to DESCRAMBLE the Dishnet Nagravision1 signal). Use a RS232 Serial Straight Through Cable and Com Port 1 on your computer. Use the flash utility uploader and X-7500 / X-5800 flash file. Download the X-7500 / X-8500.bin to the receiver from you computer as a "Flash ROM File". DO NOT, I repeat, DO NOT DOWNLOAD IT AS A "BOOT FILE" or you will fry your receiver and you will be finished with it and these instructions! Make sure your Computer says "Download Complete", not just 100%. If you don't get "Download Complete" you have NOT completed the Flash! WAIT WAIT WAIT....for your Computer to say "Download Complete" and the receiver should re-boot itself. If this has not happened, you have not flashed successfully. Do NOT go further!
| Posted on Saturday, August 20, 2005 - 09:52 am: |
I would advise everyone to read a set up guide before flashing. But, since people have been having some problems, I have revised this to provide more detailed information. But this is not intended to be a substitute. 1. Make sure you use the proper serial cable for your receiver: Fortec and Pansat use a straight through cable with DB9 females on both ends. The Blackbird and Pansat 2700 uses null (crossover) cable, which crosses over pins 2 and 3. 2, With the power turned off, connect it to your computer and receiver using the serial connector. Use serial port #! if you can. 3. If you do not have a working serial port, you must install one or use a computer that has one. 4. Use the appropriate loader. 5. Select the file. Make sure that it is the correct flash for your receiver. 6. Select the COM port your receiver is connected to. If you do not know, what it is try #1 first. 7. Enter the correct model name and number. 8. Check off the correct function box. Your choices are boot, flash or channel list. To FLASH your receiver you would use FLASH. Most flashes do not require a separate boot; so do not load both separately. 9. Turn on the receiver power from the back switch. 10. As soon as you see the lights flash,very first light -- IMMEDIATELY press download. 11. Wait until it COMPLETES and reboots.
| Posted on Saturday, August 20, 2005 - 09:57 am: |
For PANSAT 2500 autoroll, then download and unzip this file..it has the readme info and how to install included..along with the updater program to install the bin (or any bin) and gtools program to upload channel lists (optional) Pansat 2500 Software Updater & Bin.zip (size: 731.8 KB last modified: 03-23-2005 ) 2500a bin 245 SOFTWARE UPDATER INSTRUCTIONS. Turn on Receiver! 1. Open STB Updater in Step One Folder. 2. Click on Browse. 3. Choose the 2500X8500_AutoRoll_245_api_bin. & click open. 4. Leave on Bin setting and click FIX. 5. Wait untill Stb updater tells you "DONE" click OK. 6. Use G-tools to load a channel file or do a smart scan. |
Post Number: 736 Registered: Apr-05
| Posted on Saturday, August 20, 2005 - 11:40 am: |
Talking to your self again eh LK. |
| Posted on Saturday, August 20, 2005 - 12:04 pm: |
LK-you are great. I did not sleep last night for all the troubles I run into during the setting. I thank you again... |
Post Number: 738 Registered: Apr-05
| Posted on Saturday, August 20, 2005 - 12:15 pm: |
white mouse is LK. just trying to drum up more post for him to answer. |
| Posted on Saturday, August 20, 2005 - 12:30 pm: |
How about autoroll for ultralifeFortec LK? any instruction for that? |
Post Number: 740 Registered: Apr-05
| Posted on Saturday, August 20, 2005 - 12:49 pm: |
Come on LK your alais want you to talk to them. |
Montreal,
Qc
| Posted on Saturday, August 20, 2005 - 02:22 pm: |
LK what about the keys for per pay view?
Post Number: 741 Registered: Apr-05
| Posted on Saturday, August 20, 2005 - 02:25 pm: |
Oh LK has them ok . He's busy right now talking to himself. LMAO |
| Posted on Saturday, August 20, 2005 - 04:13 pm: |
HELLO SOME BODY HAS THE KEYS FOR DISHNET INCLUDED PER PAY VIEW? PLS |
New member Username: Peerlessmack
| Posted on Saturday, August 20, 2005 - 04:33 pm: |
There are no keys for PPV. Haven't you been reading? PPVs have switched to N2. There is no way to get them back unless you subscribe to D!$h. |
| Posted on Saturday, August 20, 2005 - 11:17 pm: |
does anyone knows how to get HBO? |
New member Username: Lazeress
| Posted on Sunday, August 21, 2005 - 06:33 am: |
HI new to this I have a fortec lifetime ultra and have flash it with the al7bar fta and tried the new keys that LK has posted but am only geting a screen that says scambled or blocked if any one can help that would be great thanks |
WHITE MOUSE Unregistered guest |
| Posted on Sunday, August 21, 2005 - 07:31 am: |
-Why don't U f_u_c_k off Mable Leaf u "useless B1tch. |
New member Username: Mzakcat
| Posted on Sunday, August 21, 2005 - 10:40 am: |
i am also new but i've taken all the advise, gone back and read posts from past 3 years, i've the pansat 2700a, i feel i'm ready for help. all i can hit seems to be bev and not dish. eveything is scrambled but the radio. |
| Posted on Sunday, August 21, 2005 - 10:42 am: |
any ideas???? |
| Posted on Sunday, August 21, 2005 - 10:47 am: |
realign dish , enter keys , download latest updater? i do need the help, thnx to all who got me this far |
