Thread: A question about using a computer with an HDTV card and a projector |
New member Username: Orwellsrevenge
Post Number: 1 Registered: Sep-05
| Posted on Friday, September 09, 2005 - 03:33 am: |
Can you hook up a computer with an HDTV card to an HDTV ready projector and get an HDTV signal without going through an HDTV? |
Bronze Member Username: Wearenotalone69
Post Number: 49 Registered: Aug-05
| Posted on Monday, September 19, 2005 - 01:36 am: |
HDTV card to HDTV ready projector YES, if the digital signal is correct for the "projector". http://forum.ecoustics.com/bbs/messages/2/162397.html BTW: If the HDTV ready projector is HD "ready", (meaning it does not have a HD tuner build in..). Why would you need (or want) to run it thru a HD TV, and then on to the "projector"? Seems to me a HDTV ready projector is the same as a HDTV... the only differance being one has a "built-in HD Tuner", the other requiring an external tuner. (AKA "HD Ready") |
Post Number: 50 Registered: Aug-05
| Posted on Monday, September 19, 2005 - 01:40 am: |
Bryan, BTW, How about posting the model number of the HD PC card etc,etc.... so people can better help YOU, and so this thread and posts may help others better. |
