Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > Do i flash the Pansat2500a receiver a...
Author Thread: Do i flash the Pansat2500a receiver as it is or do i have to revert it to factory settings first and then install the N2 Patch?
Do i flash the receiver as it is or do i have to revert it to factory settings first and then install the N2 Patch?
Username: Jmill1948
Chester, Va
Usa
Post Number: 726
factory setting the load original bin file then load the 251 bin file then chanel list
LK
be smart...don't put it in receiver...first U need to read much...
do U have a clone?
when was it built?
which EXACT chips are in it?...70's or 90's
do U have the boot repair file?...know how to use it?
have the 222 factory bin?
what U going to do when the keys change?
can U solder and Jtag the receiver?
If U don't know all these answers,then U are a fool to even consider using this new bin!
USA_All_The_Way
this is what lk calls help. i hope not all canadians are this dumb.
ReaI LK
Kinda funny lk I told u back on monday that peeps should flash factory first then n2 bin and u called me a idiot.. do you wanna plead ignorance or r u just a azzhole
LK
My reply is what is called intelligent...more than I can say about U!...those are honest questions and honest helpful reply!..If he can't answer or perform the functions I asked, then he shouldn't put the killer bin in his receiver.
BTW..I see U offered NOTHING except mouthage!...typical JERK kid!
BTW...I am more American than U...at least I can name the 50 states and capitals and have read the Constitution...(I'm sure U haven't reached that grade yet and I don't think they even teach that in school any more)...U dumb SOB.
Username: Fcukblklist
Post Number: 12
ok well i do have one box that has not been programmed with the new bin...here is my info
1. i do not have a clone...have checked the box by the requirments that had set out and it passed.
2.box was built mar 2004.
3.as far as the chip i opened the box and all i saw a chip and at the end of it it had -90
4.do have the boot repair file and yes i do know how to use it.
5. do not have the factory bin
6.as far as the keys changing....that part i do not know...i guess look for a new file or for the new keys
7. i do not know how to hardwire a tsop but i do have a download that explains how to do it....
so should i add the bin
LK
-I JUST WANT TO CALL U AZZ O....THE SHOE FITS
SO PUT IT ON AZZ OOOOOOOOOOOOOO.
Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > Do i flash the Pansat2500a receiver a... [ « Previous ] [ Next » ]
