Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > MAYBEE A FRIED PANSAT FIX
Author Thread: MAYBEE A FRIED PANSAT FIX
Username: Austinsec
NOT CONFIRMED PLEASE VERIFY
Hey guys, for I got the fix the dead Pansat 2500's and it works, I tested it out.
Start with the to receiver off
Find uses blacklists to uploader to the cases out and select Write
Ace it starts downloading, turn the to receiver ON
Until DON"t touch it's donates...says Completed
Turn the Pansat OFF from the back, don't let it reset
Turn it on again and it should be back to factory.
That's normal what I did and minés now up and back to.
Strangely enough, I put the Blacklist cases out on again...and it's WORKING
It didn't kill my pansat to second Time! Weird
The only problem is i dont have a choice but to start with the reciever off!
Username: Austinsec
THERE IS AN ON OFF SWITCH ON THE BACK OF PANSAT
that's dead too. what else can i do?
Username: Austinsec
THE LIGHT WILL BE OFF JUST TRY IT. FOLLOW THE STEPS WHAT CAN YOU LOOSE?
i'm getting a write faild [er1]?? Any ideas??
Username: Austinsec
KEEP TRYING THE OTHER SITE IS DOWN.
KEEP ME INFORMED. I WILL KEEP TRYING TO GET INFO
Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > MAYBEE A FRIED PANSAT FIX [ « Previous ] [ Next » ]
