Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > Can i view 110/119 at the same time???
Author Thread: Can i view 110/119 at the same time???
player256
can i view channels on 110/119 at the same time on 1 dish??? thanks!!!
Also i am not able to get p0rn on my pansat. what is up with that???
Username: Jdq
Post Number: 25
Yes you need 2 lnb and a diseq switch
P*rn is stil not avail
The Pigman
Is there any instruction on how to do this? I'd really like to know as well. Like what kind of settings do you need to perform in the menu, it only seems to download off one satellite even if I switch over to the other one to download the rest of the channels.... I'm just not getting that much PPV channels so that would be I'm not doing something right in the menu?...
cran
I would like to know if you can aim a triple lnb DTV dish to get 110/119 and how would you go about from southern alberta?
Adilson
to get 110/119 at the same time for pansat:
check your receiver settings in the antenna setup sat 110=diseqc-1, 119=diseqc-2, the switch;, birds Echo8.6/Ku at 110W and Echo7/Ku at 119W are the Dishnet birds
Username: Jdq
Post Number: 26
Tell us what you are using and we can help you better
cran
Southern Alberta. Thanks
Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > Can i view 110/119 at the same time??? [ « Previous ] [ Next » ]
