Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > Same order as dishnet channels
Author Thread: Same order as dishnet channels
Razor Ramon
Can anyone tell mw here I can get a flash to set my channel list to the same order as dishnetwork, such as if I go onto the dish net website and it says tune into channel 128 for say CNN then all I have to do is tune to channel 128 instead of finding it alphabetical? this is alot more convenient especially for PPV, any help would be great thanks.
Noah's Ark
Razor Ramon
Go search google for Channel Master and edit your channel list you can edit and sort it the way you want
Razor Ramon
Is channel master a program like G-tools or is it a piece of hardware? any site that is reliable I can grab it off of? I remember I had the channels lined up before and it was a bin file that did all the work for me, I just flashed it and all the channels went to numbers instead of like FXNWS it was 120 or whatever and it was the same order as listed in guides and dishnetwork.com, any help would be great, thanks.
Home > Message Board > Home Video > Satellite TV > Archive through September 08, 2005 > Same order as dishnet channels [ « Previous ] [ Next » ]
