Thread: Pansat 2500a Consensus |
Boy Wonder Unregistered guest |
| Posted on Monday, September 05, 2005 - 09:25 pm: |
After lot of reading here and other forums I come to conclusion that those people who flashed their boxes with original factory bin before flashing with n2 bin, didn't experience night rider or even worst - dead receivers . Temptation was to big for me so I had to test it on my own receiver (are we testers or not!!) 1.I flashed receiver with the newest factory bin .235 downloaded from pansatusa 2. Flashed the box with N2 bin-posted here 3. Downloaded back my old channel list 4. Turned the reciever on at 6.30ct - still running ,and I hope it's going to stay that way Looks like everything's there but xxx If something goes bad you'll hear from me again .I have my jtag cable ready P.S.-I'm talking about original Pansat2500, not clone |
| Posted on Monday, September 05, 2005 - 09:34 pm: |
how do u jtag a reciever.. please explain |
bigflush Unregistered guest |
| Posted on Monday, September 05, 2005 - 10:18 pm: |
Doesn't make sense. In either case, the memory is completely rewritten. |
Slapnutz Unregistered guest |
| Posted on Monday, September 05, 2005 - 10:26 pm: |
I am still working with mine aswell as I didn't want to miss RAW tonight and like you mentioned we are testers, so far I haven't had any problems with mine and it is a pansat aswell |
| Posted on Monday, September 05, 2005 - 10:29 pm: |
what file was your BIN?Did you load the original Bin first before you loaded the new N2 bin? |
| Posted on Monday, September 05, 2005 - 10:31 pm: |
File size? |
| Posted on Monday, September 05, 2005 - 10:34 pm: |
In the menu on the Pansat unit itself I went to factory default setting, then loaded the bin from blacklist site, did a blind scan and watching tv for almost 3 hours now...... |
| Posted on Monday, September 05, 2005 - 10:37 pm: |
32 was the file size I believe |
don't do it Unregistered guest |
| Posted on Monday, September 05, 2005 - 10:38 pm: |
i would pull it out and sit a while....like I said mine also was working nad now i have nothing....no lights no NOTHING... i think we've been %^&*$+ !!! |
| Posted on Monday, September 05, 2005 - 10:46 pm: |
I have a question, got the upload for the 2500, working perfect, I am getting all channels, but x channels. Will the be a fix for those, or will it just remain like this, don't get me wrong, I'm happy, but just curious. If so how, will it be another bin, or what? thanks |
| Posted on Monday, September 05, 2005 - 10:49 pm: |
Just a thought I had since its working if you default back to factory setting first as some of said it should return back to default by just flashing a new file but wouldn't the last file you had working on the unit be working when it was nagra1? If so wouldn't most of those files when they were working for clone and non clone fta units? and this new file is not for clone units, so maybe theres something in the old file if you dont do the factory default first causing these units to kill due to the previous bin that was working for clone and non clone units, just a thought I had.... Hope I didn't confuse anyone there either lol hope some of you see where I was going with that |
| Posted on Monday, September 05, 2005 - 10:51 pm: |
macho what was your file size? |
| Posted on Monday, September 05, 2005 - 11:00 pm: |
i first went back to factory bin...then loaded the new N2 bin....TV was up then click...everything went black!! No lights...no sounds ...nothing....she's dead !! |
| Posted on Monday, September 05, 2005 - 11:12 pm: |
the file size was 640 kb, still going strong |
