Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > TV power cord cut & cable input broke...
Author Thread: TV power cord cut & cable input broke off
Username: Azeliea
I found a TV outside a neighbors house waiting for the trash man. I took it inside my house to see if it was fixable. The cable input in the back is broke completely off & the power cord has been cut but there is about 2-3 inches still hanging off. Could i splice another power cord to it & seal it with electrical tape? I have an extra computer power cord i could use. Would this work? I've read earlier posts about how i could use the video/audio imputs in the back of the TV using a modulator or VCR for cable imput.
Any advice?
Username: Samijubal
Post Number: 1568
You could splice another cord, it should be soldered or use wire caps, then tape it. You should try to get the ground right, if both cords have a white line on one side, connect them together.
Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > TV power cord cut & cable input broke... [ « Previous ] [ Next » ]
