Thread: Projection tv's |
Silver Member Username: Tpizzle
Post Number: 343 Registered: Apr-05
| Posted on Monday, September 05, 2005 - 02:52 pm: |
i am big screen ignorant but am iterested in upgrading from my 20" toshiba. big screen plasma's and related tv's are quite expensive and my uncle has had problems with images burning into his screen. so how are projection tv's. you might laugh at this, but i know nothing of them. projection tvs get larger than big screens and are a little cheaper right? also do they last long and are they fully functional (cable tv, DVD viewable). what are the CONS with projectors? thanks for your help |
Unregistered guest |
| Posted on Tuesday, September 06, 2005 - 12:05 am: |
my 50 inch rear projection tv quit turning on but the stand by light still comes on is it worth fixing |
Silver Member Username: Tombo777
Post Number: 332 Registered: Jul-05
| Posted on Tuesday, September 06, 2005 - 11:52 am: |
343 posts and does not understand projection TV's? Hmmmm maybe some bait here. My advice is read more then you post. You will know all you need to know. And go to the AVS forum where people actually know something and are not just fan boys stroking each other's bad choices. |
Silver Member Username: Xgrizzlyx
Post Number: 116 Registered: Jul-04
| Posted on Tuesday, September 06, 2005 - 01:26 pm: |
lol by his name i would guess his post where spent in the speaker/sound forums :p m i bet car stereo |
