Home > Message Board > Home Video > Satellite TV > Archive through September 06, 2005 > Red Sox fans, NESN problems?
Author Thread: Red Sox fans, NESN problems?
Sox Fan
Anyone else with NESN problems? Even if you don't care, maybe you could take a moment to check.
For whatever reason NESN seems to cut in and out.
Video is fine for about 30 seconds, then scrambled or bad channel for 30 seconds.
This is the only channel this occurs.
Level 77%
Quality 99%
Altitude, MSG, FSN OH,AZ,West,FL, PPV 502 on the same transponder are all OK, no problems.
Game is on ESPN and opponent usually broadcasts, so no big deal. Just curious.
Red Sox
well its not a NESN issue cause its OK on DTV..so its either a Dishnet or your bin issue..I'd lean towards DN since all other channels on TP are good..
Home > Message Board > Home Video > Satellite TV > Archive through September 06, 2005 > Red Sox fans, NESN problems? [ « Previous ] [ Next » ]
