Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > Broken coax cable on TV
Author Thread: Broken coax cable on TV
Joe Unplugged
My son recently broke the coax connector in our television in his haste to move it. It's a large screen TV, relatively new, with other input jacks that we don't utilize. Is it possible to hook up the combo DVD/VCR to the TV without using the TV's coaxial connection?
Username: Samijubal
Post Number: 1567
Use RCA cables from the combo to the TV. Then you can use the tuner in the VHS. You'll need to set the TV on whatever input you used.
Joe Unplugged
Dave:
That was really quite easy, and worked great. I thought I had a 32" boat anchor on my hands. Thanks for your help!
Username: Samijubal
Post Number: 1583
It's better that way anyway, video is better and the audio from the VCR will be stereo, with coax it's mono.
Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > Broken coax cable on TV [ « Previous ] [ Next » ]
