Thread: Help with CS-27305 Mitsubishi TV |
New member Username: Tolby
Post Number: 1 Registered: Sep-05
| Posted on Saturday, September 03, 2005 - 01:25 pm: |
My TV does not seem to recognize all of my cable channels. It will show some of them, but others it will not change to. When I input the channel number manually, it will go to the channel, but not pick it up-just a fuzzy screen. I have tried to use the memorize channels function, but it does not change my problem. Is there a reason a TV would not pick up all the channels available from the cable company? I know I get these channels, because another tv picks them up. I am missing the original remote/user guide 1. Is there a way to reset the entire TV? 2. Is there a PDF version of an owners manual available? Any help would be appreciated. |
Gold Member Username: Samijubal
Post Number: 1552 Registered: Jul-04
| Posted on Saturday, September 03, 2005 - 01:50 pm: |
Set the cable/antenna select in the setup menus to cable, then autoprogram the channels. |
