Thread: Getting distant local channels DTV |
New member Username: Smnitro1
Post Number: 3 Registered: Aug-05
| Posted on Wednesday, August 31, 2005 - 11:17 pm: |
I already setup my programming with DTV in Iowa. I have an address in NY to send the bill. How do I go about changing my address with DTV so I can get NY local feeds, CBSE, NBCE etc. Do I need to unplug the phone line going to the receiver? Can I change my address online? Please advise. Thanks alot |
Nitro Scott Unregistered guest |
| Posted on Wednesday, August 31, 2005 - 11:22 pm: |
You must open the recver and change the blue and red wire. All done! |
Post Number: 4 Registered: Aug-05
| Posted on Thursday, September 01, 2005 - 10:00 am: |
Are you serious! Can I get some legit advice on here! |
Bronze Member Username: Slo_hand2
Post Number: 64 Registered: May-05
| Posted on Thursday, September 01, 2005 - 10:04 am: |
I do not know the answer but I'm sure someone here will be serious about your question and give you a straight answer |
Post Number: 5 Registered: Aug-05
| Posted on Thursday, September 01, 2005 - 10:48 am: |
Thanks, I would also like to know if I could get CBSE and NBCE with a FTA setup.
chicago Unregistered guest |
| Posted on Friday, September 02, 2005 - 06:28 pm: |
Nobody can get the DTV 380 channels (ABC,NBC,Fox,CBS (East and West) ) now, unless U get an FCC waiver which is next to impossible...RV's and truckers and a very few remote rural areas in the US (that can't get satellite,cable, or roof air TV) are the only exceptions..If U tell DTV U live in the NY area U can get NY LOCALS,but NOT the 380's.. With FTA U can get NY LOCALS (not necessarily the same as 380's ABC E or W etc..) based upon which satellites (110-119) U're roof dish and LNB's are aimed at,and if U have a working Nagra2 bin and a receiver that accepts N2 bins/files (co*olsat,dreambox,viewsat,some pansats now)...www.lyngsat .com lists what channels are on what satellites..U will have to check that out yourself.. |
Post Number: 8 Registered: Aug-05
| Posted on Friday, September 02, 2005 - 10:28 pm: |
I guess all I need now is a Dreambox, Nag2 bin and re-aim my DTV dishes. Thanks alot, I really appreciate your help.
