Home > Message Board > Home Video > Rear Projection TVs > Archive through September 07, 2005 > New problem with Samsung HL-R4266W HDTV
Author Thread: New problem with Samsung HL-R4266W HDTV
Username: Frankminutillo
Manchester, CT
United States
Post Number: 9
I have a new problem with a troubled Samsung HL-R4266 W HDTV purchased a month ago. When watching a program, any program through my digital cable box the picture will "freeze" and remain frozen until I change the channel and change it back using the cable box. This happens frequently and at random intervals and usually with standard ( non HDTV) cable stations. It also happens with HDTV channels but with less frequency and will sometimes un-freeze after a few seconds.
Anyone out there ever experience this? Or know how to remedy it short of calling the very oxy-moronicly named Samsung Customer Service for a warranty fix that has been a very bad experience for me with the first serious problem I had with this so called state of the art television set.
Username: Pmtre
Milford, MA
Post Number: 9
I've had similar issues mostly with HD Channels
It's happpened on both my Sammsung DLP and my Panasonic Plasma both conected to Comcast digital boxes. It appears to be more of a cable problem than set issue. It usually only lasts a few seconds, but has lasted several minutes.
Username: John_s
Columbus, Ohio
US
Post Number: 426
Before we administer stern discipline to those TVs gentlemen, make sure it's not a cable problem first.
Manchester, CT
United States
Post Number: 10
It turns out that the problem is with my cable box. One of those that automatically records as well as sends the signal to the TV. It's a pretty nice system which acts in a similar way as a TiVo too, but it does have some bugs. The problem I had was one of those bugs. I solve it by every once in while unplugging the cable box and letting it re-set.
Home > Message Board > Home Video > Rear Projection TVs > Archive through September 07, 2005 > New problem with Samsung HL-R4266W HDTV [ « Previous ] [ Next » ]
