Home > Message Board > Home Video > Projectors > Archive through October 31, 2005 > I get a better SD pic with component ...
Author Thread: I get a better SD pic with component over HDMI/DVI
Username: Dwmmlm
Weston, FL
United States
Post Number: 7
I hooked up my Toshiba DLP 52HM94 to the HD cable box and although the HD pics look great, my standard broadcasting stations look much worse than it did when I had analog feed.
What's the scoop?
Username: Maddog72
I have the same problem with my 51" sony. I am running the cable into my Onkyo and back out to my tv. The HD channels rock, but the analog looks like crap.... I have comcast. What do you have? and if you get a solution, please let me know what it is.
Username: Dwmmlm
Weston, FL
United States
Post Number: 8
I think the solution is the dish, but I do not have the option as my town is locked into a deal with a private cable company (Advanced Cable) that forces us to use cable.
I have improved it by simply NOT using the HD box input unless I am watching those channels. I split the inbound cable and one goes to the HD box and the other right to the TV. I switch the TV input back and forth between regular cable and HD depending on what I want to watch. It's a terrible solution, but the best I've been able to come up with.
tampametal
Harvey,
Run a splitter before the box and use the tv's tuner for the analog and you will see 110% difference.
Home > Message Board > Home Video > Projectors > Archive through October 31, 2005 > I get a better SD pic with component ... [ « Previous ] [ Next » ]
