Home > Message Board > Home Video > DVD Recorders > Archive through October 04, 2005 > Playing dvd on another machine
Author Thread: Playing dvd on another machine
Username: Kcee
I recorded a show on dvd+rw on my rca dvd/vcr recorder I just bought--tried to play it on my sansui dvd/vcr player and all I get is err msg. The recorder manual says some machines are not dvd+rw compatible--how do I find out if that is the reason--and does that mean i'm confined to watching in the room i taped it in. Thanks
Username: Samijubal
Post Number: 1479
Did you finalize the disc? Use R discs, the compatibility is a lot better.
Username: Kcee
My manual says you only finalize r not rw. The manual on my player says it uses dvd-r dvd-rw. So is it impossible for it to play on this machine.
Username: Samijubal
Post Number: 1486
If they are -RW, they need finalized. I don't use + discs, so I don't know if they need finalized or not.
Home > Message Board > Home Video > DVD Recorders > Archive through October 04, 2005 > Playing dvd on another machine [ « Previous ] [ Next » ]
