Thread: Can't Connect DVD Recorder to Time Warner Cable HD-DVR |
corundus Unregistered guest |
| Posted on Tuesday, August 23, 2005 - 10:20 am: |
I recently purchased a Toshiba DVD Recorder and am having no luck connecting it to my Time Warner Cable HD-DVR Reciever. Does anyone have a solution to connecting, I dont need to record HD, would be happy simply recording regular programs. I have a panasonic Wide screen tv, I guess I just need to get the wires going in the right direction, please help there is nothing in manual. Thanks in advance. |
| Posted on Tuesday, August 23, 2005 - 10:33 am: |
I forgot to mention the HD-DVR is a Scientific Atlanta Explorer 8300HD (HD DVR) Thanks again |
| Posted on Tuesday, August 23, 2005 - 11:53 am: |
"please help there is nothing in manual....." lIAR, LIAR, PANTS ON FIRE. PEAS |
| Posted on Tuesday, August 23, 2005 - 07:29 pm: |
well there is but not on HD-DVR |
Gold Member Username: Samijubal
Post Number: 1480 Registered: Jul-04
| Posted on Tuesday, August 23, 2005 - 09:36 pm: |
You can't record HD, you need to set to SD for recording. |
New member Username: Brybob2002
New York,
New York
Post Number: 1 Registered: Aug-05
| Posted on Tuesday, August 30, 2005 - 03:11 pm: |
Hooked to Time Warner HD-DVR - didn't realize until recently that recording to DVD from it was very simple - my cable hookup is cable box to DVD recorder out to TV - I have the Scientific Atlantic box and my dvd recorder has the VCR+ feature which I do not use since there is no obvious sensor on the cable box - so since it's set already to 3, I press play on what I've recorded on the DVR and record on the DVD - and it's in business. It works fine. I do find that lately Time Warner's signal seems to break up a lot, but then that's probably show biz. I'm using a Sony RDRGX300 and it's quality is great. Bob |
| Posted on Thursday, September 01, 2005 - 04:33 pm: |
thanks Rob, I will try it today. |
