Home > Message Board > Home Video > Rear Projection TVs > Archive through September 07, 2005 > Bright colored vertical lines on sony...
Author Thread: Bright colored vertical lines on sony wega 655 model
Username: Harley572
new Sony Wega KDF42WE655 2 months old Q box already replaced by sony service for cold start problem. Now set when hot and shut down then restarted after about 30 sec will take 70 blinks to come on and will either show picture and tv will not have any operating functions(channels, mute,menu,etc) or will display colored vertical lines across screen and still no operating functions. need to let bulb completly cool then picture will come up with all functions. Another call to Sony This was a floor model from PC richards hope if nec Sony will replace if can not fix. Any ideas (help).
Username: Thx_3417
Post Number: 883
Sounds like something in the electronic sensory circuits that are causing this funny?
An IC chip or somewhere along those lines...
Get the engineer, the same one that did it for you the first-time around, and if this continues get someone else to try and solve the problem, if this doesn’t help or solve the problem, get a replacement for the Sony….
Home > Message Board > Home Video > Rear Projection TVs > Archive through September 07, 2005 > Bright colored vertical lines on sony... [ « Previous ] [ Next » ]
