Thread: Panasonic PT50LC13 LCD TV |
New member Username: Tshaffer13
Post Number: 1 Registered: Aug-05
| Posted on Sunday, August 21, 2005 - 04:17 pm: |
Hi- I recently had my TV repaired (needed new light engine) and just realized when the repairman put my tv back together... he didn't do it completely correct. You know the multimedia slot on it? Well, the tab is stuck "inside" the TV (therefore I can't use it). Does anyone know how I can "break apart" the TV so I can release the tab? THANK YOU!
Silver Member Username: Tombo777
Post Number: 179 Registered: Jul-05
| Posted on Sunday, August 21, 2005 - 07:04 pm: |
How old was your PAnasonic? Was the tech from an EW company? |
Post Number: 2 Registered: Aug-05
| Posted on Sunday, August 21, 2005 - 09:34 pm: |
Panny is 1.5 yrs old - but I don't need the help now... I did some work and got it fixed! :-) For those that might have encountered the same problem - I pushed in on the top part of the multimedia "flap" and the "tab" came out. The card flap's tab is bent and the front front is warped SLIGHTLY, but it works just fine. :-) (Unforunately, I didn't figure this out until I had the back panel of the TV off!) Thanks. |
New member Username: Gjb85705
Tucson,
AZ
U:SA
| Posted on Tuesday, August 23, 2005 - 11:52 am: |
I've had my panny for almost two years and i have had to replace the bulb twice. Does anyone know if this can be fixed so that i dont spend so much money on the bulbs or is there a recall that i should know about? |
