Thread: Archive through August 07, 2005 |
New member Username: Serbia
Kitchener,
Ontario
Post Number: 2 Registered: Jun-05
| Posted on Wednesday, June 29, 2005 - 07:40 pm: |
all the sites for dishnetwork key is here |
New member Username: Bertoro
Toronto,
Ontario
Post Number: 10 Registered: Apr-05
| Posted on Wednesday, June 29, 2005 - 07:44 pm: |
mmm? |
Silver Member Username: Maple_leaf
Post Number: 456 Registered: Apr-05
| Posted on Wednesday, June 29, 2005 - 07:52 pm: |
NOT. |
Kitchener,
Ontario
Post Number: 3 Registered: Jun-05
| Posted on Wednesday, June 29, 2005 - 08:08 pm: |
Key0: 35 A5 72 32 6F 2F C3 48 Key1: 77 C4 B3 74 E0 6B 15 28 ** Active new key dishnetwork
Bronze Member Username: Bertoro
Toronto,
Ontario
Post Number: 11 Registered: Apr-05
| Posted on Wednesday, June 29, 2005 - 08:11 pm: |
miff wrong !!! working key 00 11 64 6b 2e a5 26 ed 7e |
Kitchener,
Ontario
Post Number: 5 Registered: Jun-05
| Posted on Wednesday, June 29, 2005 - 08:32 pm: |
00 10 c4 6b 2e a5 26 ed 7e 01 82 d7 51 e4 5b 97 9d 81 real code i swear on my life |
| Posted on Wednesday, June 29, 2005 - 08:59 pm: |
DISHNET KEYS Current 06-29-05 07:00pm EST Key0: 11 64 6B 2E A5 26 ED 7E Key1: 40 B2 B9 7A C2 C1 53 75 ** Active
Bronze Member Username: Stevez01
Mississauga,
Ontario
Post Number: 34 Registered: Mar-05
| Posted on Wednesday, June 29, 2005 - 10:21 pm: |
sorry gizmo. Appreciate every time you put up codes, but the above ones just do not work. Any ideas my friend? |
Toronto,
Ontario
Post Number: 17 Registered: Apr-05
| Posted on Wednesday, June 29, 2005 - 10:23 pm: |
steve, email me for the numbers or read my posts for them.... |
Mississauga,
Ontario
Post Number: 35 Registered: Mar-05
| Posted on Wednesday, June 29, 2005 - 10:27 pm: |
ferenck, just private messaged you. Hope that works. Thanks so much |
Toronto,
Ontario
Post Number: 19 Registered: Apr-05
| Posted on Wednesday, June 29, 2005 - 10:33 pm: |
steve...how do i check private messages? i cant find them.... tnx |
Key0: 11 64 6B 2E A5 26 ED 7E <--Active Key1: 40 B2 B9 7A C2 C1 53 75 Dishnet changed the ACTIVE key tonight (7:30 PM EST)from Key 01 to now KEY 0...so if U change them both now ,then U should be all set. |
New member Username: Artinusa
Post Number: 1 Registered: Jun-05
| Posted on Thursday, June 30, 2005 - 02:23 am: |
what is cine+Digital PPV(012010) |
| Posted on Thursday, June 30, 2005 - 02:24 am: |
thank you Gizmo |
| Posted on Wednesday, July 06, 2005 - 08:37 pm: |
who knows dish codes |
chicago Unregistered guest |
| Posted on Wednesday, July 06, 2005 - 09:28 pm: |
DISHNET KEYS Current 07-06-05 07:00pm EST Key0: A1 8B 3F 9C 3C 90 94 8F ** Active Key1: 40 B2 B9 7A C2 C1 53 75 These are current and working keys...do a reboot/reset (BACK of receiver,power OFF,wait 2 minutes,power ON,go to channel 300) AFTER changing the keys.. BTW..a reboot/reset should always be tried whenever U have any problems.. |
Post Number: 4 Registered: Jun-05
| Posted on Wednesday, July 06, 2005 - 10:31 pm: |
thank you very much!!!!!!!!!!!!!!!1 |
Post Number: 6 Registered: Jun-05
| Posted on Thursday, July 07, 2005 - 02:27 pm: |
here is the new key KEY0: A1 8B 3F 9C 3C 90 94 8F KEY1: C4 82 37 AA 5B C2 2D E5 AUX0: 82 D7 51 E4 5B 97 9D 81 AUX1: 65 57 46 14 36 02 D8 DA
New member Username: Matrix68
Post Number: 1 Registered: Jul-05
| Posted on Thursday, July 07, 2005 - 05:38 pm: |
What program is used to upload the autoroll bin to the fortec star receiver. I hate putting the keys in almost everyday. |
buffalo Unregistered guest |
| Posted on Friday, July 08, 2005 - 08:55 am: |
fabian.. Click on UPDATER.EXE to start it. Set the COM PORT and put a dot in BIN. Click on BROWSE then put in Al7bar FTA Ultra_050616_276_api(NTSC).bin (note it is a bin) Turn receiver on from the back, when FIRST bar starts then click FIX on your computer. After you get COMPLETE on the computer the ON will display in the receiver, then it will displays a channel number, if you have channels in your receiver. Your receiver is flashed. You should be on a working channel (300) with signal for the auto roll to work. When you turn the receiver & TV on after the flash you may get ECM has occurred with a %. Let the % go up until the picture comes on. It is looking for the keys. It may take 5 minutes. The % may go to 115 or more. If for some reason it can't find the keys then set the default key by clicking on MENU, then go to CHANNEL EDIT, then CODE, then OK, put in 1010 or 1668 what ever works, then down to SET DEFAULT KEY and click OK ,then exit out
Doug J. Unregistered guest |
| Posted on Friday, July 08, 2005 - 12:05 pm: |
hi guys. I've been reading alot about the "300 channel trick". fo what is it used ? Thanks for any info. |
New member Username: Bekim
NY,
NY
Post Number: 7 Registered: Jun-05
| Posted on Friday, July 08, 2005 - 02:58 pm: |
Does anyone know if there is a file to download in the Cool**t 4000pro to decode Irdeto 2? Thank you! |
| Posted on Friday, July 08, 2005 - 05:20 pm: |
Does any one have the new keys thanks |
| Posted on Friday, July 08, 2005 - 05:28 pm: |
Bekim..Irdto2 has not been hacked DISHNET KEYS Current 07-08-05 04:30pm EST Key0: C7 81 C8 80 A5 61 54 59 ** Active Key1: C4 82 37 AA 5B C2 2D E5 |
Toronto,
Ontario
Post Number: 21 Registered: Apr-05
| Posted on Friday, July 08, 2005 - 05:32 pm: |
thanks chicago !!!! |
| Posted on Sunday, July 10, 2005 - 08:08 am: |
i put codes in but all i get is 1 to 120 with dead air and I can't get other channels.. Also my signal level is at 92% and quality is 0%. Can some help me? |
| Posted on Sunday, July 10, 2005 - 02:51 pm: |
Dear anonymous, The link you have posted on every forum string is great but..... It still has keys from Jul 8, when will it update and does anyone else have live keys? |
| Posted on Sunday, July 10, 2005 - 03:34 pm: |
that site is linked to the "getkeys" file (www.bevkeys.com)...also the Keymaster.exe file will get U the keys immediately...sites do not post "live" anymore,only when they change..thats as "live" as it gets..use the getkeys or keymaster file instead of trying to get into some site during heavy traffic peak periods...get the keys whenever U want them,right from your own computer... BTW...keys have NOT changed since then either..this I just got from the keymaster.exe file on my puter in 2 seconds...its the Latest and current working keys which changed LAST at 4:30PM on 8 July as shown.. DISHNET KEYS Current 07-08-05 04:30pm EST Key0: C7 81 C8 80 A5 61 54 59 ** Active Key1: C4 82 37 AA 5B C2 2D E5 |
New member Username: Kingb
| Posted on Wednesday, July 13, 2005 - 08:14 pm: |
what is the latest key
Toronto,
Ontario
Post Number: 22 Registered: Apr-05
| Posted on Wednesday, July 13, 2005 - 08:19 pm: |
18 05 94 5d 50 e7 a1 c8 -key 01 |
| Posted on Thursday, July 14, 2005 - 01:08 pm: |
anyone has today key pls? |
wolverine Unregistered guest |
| Posted on Thursday, July 14, 2005 - 01:28 pm: |
need new dishnet keys if anyone has them |
| Posted on Thursday, July 14, 2005 - 01:40 pm: |
What are todays dishnet keys? Thanx |
| Posted on Thursday, July 14, 2005 - 01:46 pm: |
key 0---AC 7D CF 36 D5 32 9B 5D active Key 1---18 05 94 5D 50 E7 A1 C8 |
| Posted on Thursday, July 14, 2005 - 05:56 pm: |
KEY0: AC 7D CF 36 D5 32 9B 5D KEY1: 18 05 94 5D 50 E7 A1 C8 AUX0: 82 D7 51 E4 5B 97 9D 81 AUX1: 65 57 46 14 36 02 D8 DA
| Posted on Thursday, July 14, 2005 - 07:32 pm: |
does anyone know how to program the pansat 2500A for auto roll over |
New member Username: Fenil532
| Posted on Friday, July 15, 2005 - 05:23 am: |
i have the fortec Star system. I put the lastest codes in but all iI get is 8 channels on echo 110, 119 and they are the free channels. what am I doing wrong so that i may get more channels? |
New member Username: Dnicholls
Pickering,
Ontario
| Posted on Friday, July 15, 2005 - 09:43 am: |
I have a Digiwave 6800. I cannot get a good signal no matter what I try. I have gone as far as hooking the receiver up to a friends dish, he gets 85% and I get 40% pointing at xpressvu. We just put the new autoroll on for the Digiwave 7000 and tried going to Dishnet. It downloads approx 300 channels but stays scrambled. Is this fixable or is the 6800 a piece of crap. Thanks Dave |
| Posted on Friday, July 15, 2005 - 08:07 pm: |
What are todays dishnet keys? Thanks. |
pulamea Unregistered guest |
| Posted on Friday, July 15, 2005 - 10:15 pm: |
Does anyone know today's dishnet keys? Thank you. |
New member Username: Kanimass
Ca
| Posted on Friday, July 15, 2005 - 11:59 pm: |
hey guys what are the keys for today...? July 15 2000005, thnks |
| Posted on Saturday, July 16, 2005 - 12:13 am: |
DISHNET KEYS Current (KEYMASTER) 07-14-05 1:00pm EST Key0: AC 7D CF 36 D5 32 9B 5D Key1: E9 FD 53 DE B5 37 FC 44 ** Active MAESTRA KEY0 -- AC 7D CF 36 D5 32 9B 5D KEY1 -- E9 FD 53 DE B5 37 FC 44 Active 15-07-05 18:57:40 |
| Posted on Wednesday, July 20, 2005 - 04:32 pm: |
| Posted on Thursday, July 28, 2005 - 08:13 pm: |
What are the latest keys for Thursday July 28, 2005? |
skipper Unregistered guest |
| Posted on Thursday, July 28, 2005 - 08:28 pm: |
who as the keys? |
| Posted on Thursday, July 28, 2005 - 10:02 pm: |
anyone who can't get the keys themselves without coming here,shouldn't even have FTA! |
AUTOROLL Unregistered guest |
| Posted on Thursday, July 28, 2005 - 10:17 pm: |
GET AUTOROLL!!!!!!!!!!!!! |
shehond Unregistered guest |
| Posted on Thursday, July 28, 2005 - 10:27 pm: |
what is auto roll? Does anyone have the keys? I am new to this. |
| Posted on Friday, July 29, 2005 - 07:39 am: |
this latest bin file has autoroll update to bin 276 or newer and the keys will update themselfs |
| Posted on Friday, July 29, 2005 - 11:49 am: |
Latest keys A http://dss.br.n*u Take the * from nu |
Silver Member Username: Hamtec
Post Number: 223 Registered: Jun-04
| Posted on Friday, July 29, 2005 - 02:33 pm: |
The codes have not changed for over 2 weeks enjoy.I beleave that dish is busy trying to ecm the latest n2 hack and are not changing the keys.this will not last long but who cares the n2 is fixed and the coders are doing the right thing by releaseing plastic hack for old rev cards first but to late. FTA hacks should not be released until n1 is gone. Once n1 is gone them we will all have hacks for all ftas all cards and dish will have lots of hacks to kill and will not be able to keep up. Remember all the coders learned from the p4 and do not make the same misstakes twice. |
Twinky Wonder Unregistered guest |
| Posted on Friday, July 29, 2005 - 02:47 pm: |
the keys changed yesterday 28-07-05 17:42:10 KEY00.... C1 AE 0A 78 65 47 BB E4 <----Active KEY01.... E9 FD 53 DE B5 37 FC 44 |
Post Number: 226 Registered: Jun-04
| Posted on Friday, July 29, 2005 - 02:51 pm: |
My keys have not changed for 2 weeks so I don't know what all the talk is about. |
Post Number: 227 Registered: Jun-04
| Posted on Friday, July 29, 2005 - 03:36 pm: |
I have always said I would meet you anytime anywhere. I would like to see the p4 hack working before I say or do anything this still stands. |
| Posted on Friday, July 29, 2005 - 09:09 pm: |
hey guys i need help can some one give me the new keys for dish fortec star |
| Posted on Friday, July 29, 2005 - 09:14 pm: |
DISHNET KEYS Current 07-29-05 5:20pm EST Key0: C1 AE 0A 78 65 47 BB E4 Key1: BC B0 95 AC 66 E9 A7 42 ** Active |
| Posted on Friday, July 29, 2005 - 09:24 pm: |
DOES ANYONE KNOW TO PROGRAM THE PANSAT 2700A FOR AUTO ROLL OVER THANKS |
| Posted on Saturday, July 30, 2005 - 08:37 am: |
thank you for the keys lk but the dont work i dont know why.can u help plz |
| Posted on Saturday, July 30, 2005 - 01:28 pm: |
I HAVE PANSAT AND PRACTICALLY I AM LOOSING ALL MY CHANNELS. MY PANSAT SCANS ITSELF FOR THE NEW KEYS BUT STILL DON'T GET THESE CHANNELS BACK. SOMEBODY TO HELP ME!!!!! |
slimthug1 Unregistered guest |
| Posted on Saturday, July 30, 2005 - 02:57 pm: |
do u noe how to open the ppv channel it has a 4 digit codeon it an i dont know the password/code for ppv movies so can anyone help me. also can someone explain wat the key is all about please and where u enter it |
| Posted on Saturday, July 30, 2005 - 04:10 pm: |
READ, READ, READ AND APPLY AND APPLY FOR FTA HELPS: www.pantecdvb.com www.dssftp.com (public download)(FTA) |
slimthug1nasir Unregistered guest |
| Posted on Saturday, July 30, 2005 - 10:08 pm: |
my ppv channels say u have to purchase these channels and has a 4 digit password/code can anyone help me find out wat that 4 digit code is? |
| Posted on Monday, August 01, 2005 - 03:23 pm: |
anyone noe dishnetwork ppv 4 digit codes? |
| Posted on Monday, August 01, 2005 - 07:52 pm: |
anyone have new dishnet keys for aug 01 |
| Posted on Monday, August 01, 2005 - 08:00 pm: |
DISHNET KEYS Current 08-01-05 5:20pm EST Key0: 76 FE 6D E5 16 2E 46 97 ** Active Key1: BC B0 95 AC 66 E9 A7 42 |
New member Username: Bobbyc
Post Number: 1 Registered: Aug-05
| Posted on Monday, August 01, 2005 - 09:19 pm: |
LK, Thanks for the keys. Bobby C |
| Posted on Monday, August 01, 2005 - 09:37 pm: |
Thanks Milli for info.Ive heard also that ww.dsstoybox.com have wide open dish fix .ALL CHANNELS OPEN check my site out www.dssmilli.com for my activator fix also thats been up for over a month also. That www.dsscentral site are BIG SCAMMERS ive heard.They charge big money to join there hokey pokey site..Oh dont listen to this fake LK guy he is a fake out to discredit the real LK LK |
| Posted on Thursday, August 04, 2005 - 01:56 pm: |
New member Username: Apesetas_25
| Posted on Thursday, August 04, 2005 - 02:10 pm: |
8/04/05 Key:1 88 7B D0 37 D9 BA 43 73 ENJOY |
Post Number: 2 Registered: Aug-05
| Posted on Thursday, August 04, 2005 - 02:13 pm: |
I am new here and would like to recommend keeping this site serious and quit the name calling so we can get this N2 to work. "Lets do it" |
| Posted on Thursday, August 04, 2005 - 03:03 pm: |
DISHNET KEYS Current 08-04-05 1:25pm EST Key0: 76 FE 6D E5 16 2E 46 97 Key1: 88 7B D0 37 D9 BA 43 73 ** Active |
dssdan40 Unregistered guest |
| Posted on Friday, August 05, 2005 - 08:23 pm: |
dishnet keys have changed again. How do I fix this constant key changing B.S. with my fortec lifetime ultra or Pansat 2500A. Any help would be apreciated. The latest keys would be a good start. Thanks |
| Posted on Friday, August 05, 2005 - 08:33 pm: |
DISHNET KEYS Current 08-05-05 7:25pm EST Key0: A6 00 E2 C0 56 7E 4A 45 ** Active Key1: 88 7B D0 37 D9 BA 43 73
| Posted on Friday, August 05, 2005 - 08:37 pm: |
Aug 5th 8:30 pm edt Key0: 76 FE 6D E5 16 2E 46 97 active Key1: 88 7B D0 37 D9 BA 43 73
| Posted on Friday, August 05, 2005 - 08:41 pm: |
noob...wrong!..those are the OLD keys,as U should be able to see from the posts dated yesrday! Can U count up 4 posts?...and read? |
Post Number: 5 Registered: Aug-05
| Posted on Friday, August 05, 2005 - 09:17 pm: |
lk, did you receive the question about whether or not a dish network dish and direct tv dishes were interchangable? bc |
| Posted on Friday, August 05, 2005 - 09:53 pm: |
you're right LK..i cut and pasted the wrong set of keys |
mike iron Unregistered guest |
| Posted on Friday, August 05, 2005 - 11:07 pm: |
any new key yet?. |
| Posted on Friday, August 05, 2005 - 11:27 pm: |
mike...U're dumber than Tyson! |
New member Username: Poppaslim
Toronto,
Ontario
| Posted on Friday, August 05, 2005 - 11:36 pm: |
hey lk i live in canada and i just tried the codes and they work thanks bro
Toronto,
Ontario
| Posted on Friday, August 05, 2005 - 11:39 pm: |
just found this site today seems good tome |
help me plz !!!!! Unregistered guest |
| Posted on Friday, August 05, 2005 - 11:40 pm: |
lk god damn man i need some help... |
Toronto,
Ontario
Post Number: 3 Registered: Aug-05
| Posted on Friday, August 05, 2005 - 11:46 pm: |
where do u get the keys from LK? |
Toronto,
Ontario
| Posted on Friday, August 05, 2005 - 11:47 pm: |
New member Username: Monkey
| Posted on Saturday, August 06, 2005 - 01:43 am: |
I have a dish 500 DVR, worked great till I, well I HACKED it....Now when I try to view channels that I used too recieve' through a contract with DISH Network. I cant see anything' its as if there is nothing from the reciever reaching the TV. I used the "Husk-Varna" double edged, tampered steel, lumberjack edition.... Its good for "hacking"....bad for "signal reception.. |
| Posted on Saturday, August 06, 2005 - 01:49 am: |
Oh yeah by the way i also pasted "KEYS", all over it and it didnt pick up a damn thing, what am I doing wrong? Perhaps i should try some krazy glue or some sort of butt putty , they both adhere really well, better than paste... Paste is for kindergarten..... |
Elmer Ganja Unregistered guest |
| Posted on Saturday, August 06, 2005 - 05:41 am: |
Hi Friends, Be thankful for the enjoyment we all get from viewing free Satelite TV. To you idiots who ask where LK gets the key codes, your brain cells are rotten to the core! Get a lobotamy ASAP! This is your only hope! Either this, or being beheaded in Iraq would help you! LK is to be commended! Elmer Ganja |
| Posted on Saturday, August 06, 2005 - 08:22 am: |
There are many FREE software files out there available at every reputable DSS site that produces the NEW keys for you directly to your computer (just be online at no specific site), every time they change..KEYMASTER is my choice,as well as Getkeys and Jeepers..dsscommunity. com has KEYMASTER in the File Share FTA area available for U to FREE download.. |
| Posted on Saturday, August 06, 2005 - 04:15 pm: |
Aug 6, 2005 1:10PM PST key0: A6 00 E2 C0 56 7E 4A 45 (active) key1: 88 7B D0 37 D9 BA 43 73
Post Number: 652 Registered: Apr-05
| Posted on Saturday, August 06, 2005 - 06:24 pm: |
Horseshit they are wrong you dummy. |
ThiIl 1951 Unregistered guest |
| Posted on Saturday, August 06, 2005 - 06:34 pm: |
MAPLE LEAF HAS GONE BERSERK |
Post Number: 654 Registered: Apr-05
| Posted on Saturday, August 06, 2005 - 06:39 pm: |
You think so idiot. Not yet why post the wrong ## unless you don't know the right ones LMAO |
| Posted on Saturday, August 06, 2005 - 09:33 pm: |
-(MABLE LEAF)-Got my "nuts" in his mouth... He is going for my dick now... O no he just swallowed my dick... O,O,O,O, I just came my lump in his mouth... O my, the cream is running out of his mouth... O Mable loves it he's smiling and laughing... O me, O me, O me, he won't go away. |
| Posted on Sunday, August 07, 2005 - 01:20 am: |
LK go to hell |
| Posted on Sunday, August 07, 2005 - 04:13 am: |
yo KG its me from b-town |
| Posted on Sunday, August 07, 2005 - 11:29 am: |
hey guys can someone plz help me the new dishnework keys dont work i have a (fortec lifetime ultra)and i dont know y it dont work if someone can help id be more then grateful. thanx |
| Posted on Sunday, August 07, 2005 - 11:38 am: |
Those keys posted earlier: Aug 6, 2005 1:10PM PST key0: A6 00 E2 C0 56 7E 4A 45 (active) key1: 88 7B D0 37 D9 BA 43 73 Work for me on ECHOSTAR 119 Thanks very much! |
Post Number: 661 Registered: Apr-05
| Posted on Sunday, August 07, 2005 - 12:06 pm: |
Bull you know they don't MR mod. |
Post Number: 662 Registered: Apr-05
| Posted on Sunday, August 07, 2005 - 12:09 pm: |
This is new key 00 = A6 00 E2 C0 56 7E 4A 45
| Posted on Sunday, August 07, 2005 - 12:12 pm: |
Maple Leaf can you help plz the new dishnework keys dont work i have a (fortec lifetime ultra)and i dont know y it dont work if you can help id be more then grateful. thanx |
