Thread: Good/Bad points of projectors used for viewing tv/dvd/xbox............ |
Unregistered guest |
| Posted on Wednesday, March 31, 2004 - 02:24 am: |
hi all, jus wondering wot the good and the bad points/things of a projector are when used for viewing tv/dvd's/ and xbox games.........??? oh yeah, and how much are they in Australia?? |
Ed Sullivan Unregistered guest |
| Posted on Saturday, July 17, 2004 - 05:28 pm: |
lmap life usally from 2000-5000 if your luck (5000) and turning on and off a ton will kill the life more i would suggest using the projector for jus the dvds and still have a crt tube tv or lcd for the other to conseve bulb life |
| Posted on Wednesday, June 29, 2005 - 02:10 pm: |
u r sick |
New member Username: Saaketham
Post Number: 3 Registered: Jul-05
| Posted on Tuesday, July 12, 2005 - 12:21 pm: |
----------- Good Points ----------- - Unmatched and amazing screen size This makes gaming, movies etc very immersive, as you get caught up in the action, because the figures on screen are larger than life. Its quite a feeling. - Very portable You can take it to friends' places (assuming you have friends LOL), for video game parties and play like never before Those are the only good points with a projector setup, but the first point is worth several points. :-) ---------- Bad Points ---------- - Costly bulb changes Not feasible as a full-time viewing device, because of this. - Fan noise, especially if the projector is placed closed to viewers - Need for darker rooms, depending on brightness of the projector - Screen-door effect with LCD projectors - Rainbow effect with DLP projectors - For the same price as a Panasonic ET-LAE700, you can get a Sony Wega 42" LCD rear-projection TV, thats much brighter, much more convenient and much more stylish and sleek. Anil |
