Home > Message Board > Home Video > Rear Projection TVs > Archive through September 07, 2005 > Blue ghost - shadow images on samsung...
Author Thread: Blue ghost - shadow images on samsung dlp 5063
Username: Bas_53e
New YORK, NEW YORK
Can someone help me - I have these blue ghost images or shadows that are accentuated depending upon the lighting in the scene/movie. I've tried piddling with the settings through the menu to no avail. It's kind of a halo type effect. Seems like this would be a common problem with a relatively easy solution. FYI I'm using my Samsung in conjunction with a Rotel 1056
Username: Fyi
Dallas, Texas
Post Number: 219
Sure sounds signal related.
I've never heard of ghosting on a DLP.
Are you running video through the Rotel?
Try direct.
Component connections or DVI/HDMI?
Make sure connectors are seated well.
Cable, Sat, or off-air?
Do you have another signal source to try?
DVD player does the same thing?
Game box?
Home > Message Board > Home Video > Rear Projection TVs > Archive through September 07, 2005 > Blue ghost - shadow images on samsung... [ « Previous ] [ Next » ]
