Thread: HL-R 4677W vs. HLN437W |
New member Username: Pmtre
Milford,
MA
Post Number: 7 Registered: Aug-05
| Posted on Monday, August 15, 2005 - 08:44 am: |
Thinking about moving into the HLR4677 from the HLN437W I'm restricted by the cabinet size which is only 42" X 30" so anything larger won't fit. It will cost me about $1200.00 to make the move. (After credit from AMEX,unless I can unload the HLN437W which needs a DMD board, any market for these?) Do you think its worth it. The set is only used for watching HD cable TV, and DVD's. |
Silver Member Username: Fyi
Dallas,
Texas
Post Number: 215 Registered: May-05
| Posted on Monday, August 15, 2005 - 10:04 am: |
Yea, it's worth it! Use your AMEX credit. That will be a sweet upgrade. |
