Thread: Buying a Samsung DLP |
New member Username: Rb0049
Post Number: 4 Registered: Aug-05
| Posted on Saturday, August 13, 2005 - 03:22 am: |
So I narrowed down my search to a Samsung HL-R4266W or HL-R4667W. Both supports up to 720p. Shoud I be concerned it doesn't support 1080i and 1080p(i know 1080p is still new)? And how would that affect my HDTV experience in the future? If you know of a good DLP TV for recommendation please feel free to suggest one. (around 42"-46" range). Thanks in advance. |
Silver Member Username: Fyi
Dallas,
Texas
Post Number: 209 Registered: May-05
| Posted on Saturday, August 13, 2005 - 11:04 am: |
rob, You have a misunderstanding about supported formats. Both sets are actually native 720P displays. This means they will accept any format and scale it to 720P. This includes 1080I. There isn't a single network broadcasting 1080P and there probably won't be for many years. Sets with native 1080P displays are scaling input signals to 1080P. I like the R4667. Bigger is better with HD. |
Post Number: 5 Registered: Aug-05
| Posted on Saturday, August 13, 2005 - 04:12 pm: |
oh okay. thanks for the clear up. |
| Posted on Thursday, August 25, 2005 - 09:28 am: |
I'm looking at two Samsung DLP: HL-R5667W and HL-5677W. What are the pros and cons of these sets. I care more about picture quality and stability than features such as 2 tuners for PIP. Also phyical size doesn't matter since its going into a 20 x 20 room. This room also gets plenty of sunlight. Are there other sets I should be looking to buy instead? Thanks in advance for any information. |
Silver Member Username: Tombo777
Post Number: 204 Registered: Jul-05
| Posted on Thursday, August 25, 2005 - 09:39 am: |
I'd steer clear of DLP or RPLCD unless you do not mind spending 10-15% of the TVs cost every year or two for proj bulb replacement. Too many issues. Find a decent RP CRT set save a bunch then with your savings in a few years buy an established fixed pixel technology. Otherwise go for a Plasma today if you have to have the few HD broadcasts available. |
Against the Rant Unregistered guest |
| Posted on Friday, August 26, 2005 - 10:18 pm: |
Don't believe tom bong! He's a ranting repetative idiot. I'm not sure why he keeps repeating false information. It seems more like a self affirmation of his own propaganda. He acts like he's on some kind of self appointed mission to save us from technology advances. What a total moron! Buy what you want, when you want it. |
