Home > Message Board > Home Video > Rear Projection TVs > Archive through August 12, 2005 > Hitachi Rear Projection TV CU4601K go...
Author Thread: Hitachi Rear Projection TV CU4601K goes into power shutdown
I have a 12 yaer old Hitachi, model CU4601K rear projection TV which worked great till a couple of days ago.
Now it turns ON with distorted color for 1/2 minute then shuts down. You can switch it on again after an hour, but shuts down agin after few seconds. Seems like some Circuit Protection circuit.
Called a technician, who said the Regulation is Off. It would cost about $400 - $500 (depending if needs new regulator pair) to fix it.
Is that possible & reasonable OR am I being conned? Technician never opened set & took 1 reading with DVM at back.
Home > Message Board > Home Video > Rear Projection TVs > Archive through August 12, 2005 > Hitachi Rear Projection TV CU4601K go... [ « Previous ] [ Next » ]
