Thread: Magnavox TV help |
New member Username: Lisa82
Post Number: 1 Registered: Aug-05
| Posted on Sunday, August 07, 2005 - 10:55 pm: |
I have a 32" Magnavox model number MS3250C121 about a month ago when we turned it off then turned it back on the picture wouldn't come back. The sound was fine. After a while of being left on the picture came back it was in the center of the tv all wavy with white lines at first then it went back to normal after a few minutes. The next time we turned it off it did the same thing. So we decided to leave it on. About a week ago the side of the screen would sort of wave a bit but then go back to normal hardly noticable. A few days ago it turned its self off. The power light comes on but the picture will not come back. And if we leave it on it turns its self off. Any ideas what it might be and how to fix it? Thanks. |
Relevant Product Info
New member Username: Rms
Post Number: 1 Registered: Sep-05
| Posted on Thursday, September 01, 2005 - 01:43 pm: |
I have a Magnavox TV (sorry, don't know the model#) that a friend just gave us. Picture's great, I just can't get the remote to work from a distance farther than 2 feet away from the set. It's not the remote, as I've tried three different ones. Is there something I can do to increase the tv's infra-red range? |
New member Username: Cdarling1
Houston,
TX
| Posted on Sunday, September 18, 2005 - 04:39 pm: |
I Have a magnavox #MS3250C121 Color TV, I turn it on and it starts to come on then goes off, the power light stays light. I keep turning it on for about 20 to 30 times then it stays on. Can you help with this problem |
New member Username: Lwed
| Posted on Monday, September 19, 2005 - 11:06 am: |
I purchased a used Magnavox TV Model TP2792 B103. It doesn't have a manual. The problem is the previous owner changed the channel display. For example, he changed things from CBS to SNOT, etc., & he fogot how he did it. How can I get my TV to show the proper station display? The channel numbers are okay, but they don't match the right stations. Thanks for any help. |
Post Number: 2 Registered: Sep-05
| Posted on Monday, September 19, 2005 - 11:09 am: |
I purchased a used Magnavox TV Model TP2792 B103. It doesn't have a manual. The problem is the previous owner changed the channel display. For example, he changed things from CBS to SNOT, etc., & he forgot how he did it. How can I get my TV to show the proper station display? The channel numbers are okay, but they don't match the right stations. Thanks for any help. |
Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 10:52 am: |
At the end of a movie I went to change the channel and the tv went into "demo mode". A self-promoting advertisement for the tv scrolls over and over. The television displays what is in the ad (eg. the caption comes on when they talk about caption and the sleep timer is demonstrated). The sound and picture quality are fine, but I can't watch real tv because the set won't respond to the remote or manual stimulation.
| Posted on Thursday, October 06, 2005 - 02:22 am: |
my magnavox also went into demo mode. How in the world can I get it to go away? |
| Posted on Sunday, October 09, 2005 - 07:38 pm: |
Hi, I have a Magnavox television (I don't know which model). I have had it for a few years and enjoyed it very much. All of a sudden something happened with the color of the picture. It seems to have mixed colors of green, yellow, green, etc. all over the place. I tried fixing the tint but nothing helped. Please e-mail me at JerseyNets144@netscape.net if you can help me in any way. Thanks |
| Posted on Thursday, October 20, 2005 - 02:37 pm: |
my magnavox also went into demo mode. How can I get it to go away? |
| Posted on Monday, October 24, 2005 - 12:58 pm: |
i have a magnavox big screen and the picture is real cloudy! what can i do to fix this??? |
bouncer Unregistered guest |
| Posted on Wednesday, October 26, 2005 - 08:43 pm: |
I have a 46" Magnavox approx 8 years old. 2 of the 3 projection lens are not working. Is this worth repairing or should I just buy a new one? What would be a estimate of what this could cost? Thanks |
sexy lady Unregistered guest |
| Posted on Friday, October 28, 2005 - 09:42 pm: |
I have a 1995 magnavox (FP5230 W105 model). I have my dvd player connected to my tv. But when I try to watch a movie I do not get a picture. I can here it but I can not see it. I thought it might be the dvd player but I tried it on another tv and it worked fine. Any suggestions as to what is causing this problem? |
| Posted on Saturday, October 29, 2005 - 12:12 am: |
We have an older 25-inch Magnavox TV (Model #13PR12 C121). We've never had any trouble with it until today. It just went off and we can't get it to come back on! I've tried using the remote, manually turning it on and even unplugged it briefly (one of the troubleshooting tips in the manual) and then tried again. Any ideas? |
| Posted on Sunday, October 30, 2005 - 10:46 pm: |
i have a color magnavox tv, its about 10-30 years old, i was watching it last week and when i was about to go to sleep, i try to turn it off, at first it buzz a little bit then d picture came on again, so i try a couple of times. then i decided to take the plug out of the elctrical plug in, when i plug it back in, it wont turn on at all. please help me, andy_who_08@yahoo.com |
New member Username: Jcollins
Locust Grove,
Arkansas
Post Number: 1 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 01:35 am: |
I have a 60" magnavox projection tv can't seam to adjust color has blue and red radiating out from words and pictures have tried adjusting convergence helps but does not solve problem |
New member Username: Charlesandwanda
| Posted on Monday, October 31, 2005 - 09:05 am: |
We have a Magnavox RS2745-C206 chasis# 27S101-00FF. All of a sudden, the tv will not turn off - we have to unplug it and when you plug it back in, it comes on but you have to press the on/off button in order to change the channel or anything. I noticed that on a few posts - someone said something about demo mode. Any ideas? |
Bronze Member Username: The_nerdly_guy
Post Number: 30 Registered: Apr-05
| Posted on Wednesday, November 02, 2005 - 05:44 pm: |
I found this at TechLore, maybe it'll solve your Magnavox demo mode problems: "Ask The Experts: How To Disable Demo Mode on a Magnavox TV" |
Post Number: 2 Registered: Oct-05
| Posted on Thursday, November 03, 2005 - 08:04 am: |
Nerdly Guy - thanks for the information. We have tried to do that hold the vol+/- button down and it goes all the way through the countdown but - it still will not turn off. We e-mailed Magnavox directly, they gave us a phone number to call. We will post the results for anyone else that is having the same problem. |
| Posted on Monday, November 21, 2005 - 10:58 pm: |
I have a 24 inch Magnavox tv/vcr/dvd combo that is 2 months old. MWC24T5 My problem is when I rewind a VCR tape, the tv shuts off. I turn it back on and it ejects the tape. Very annoying. I hope someone here can tell me something very easy I need to do to stop it. Could you please reply via email? Thanks a bunch! RockAnnK@aol.com |
| Posted on Tuesday, November 22, 2005 - 08:16 pm: |
I have a magnavox 15 inch LCD tv model #15mf050v/17 for almost a year. My problem is is will not turn on either by the remote or manually. On the tv a red light flashes(led). Could you reply via email? thank you!mjablonski@ne.rr.com |
| Posted on Friday, November 25, 2005 - 06:33 pm: |
I have a 27" Magnavox TV that turns itself back on! It stays off anywhere from 1 minute to five minutes and comes back on! If you can help I'd appreciate it. |
| Posted on Wednesday, November 30, 2005 - 08:36 pm: |
We got a Magnavox 27" TV, Model #27MT3305/17, and it is turning on by itself. We called Magnavox and the CSR joked that the TV "was lonely" and "crying out for attention" (REALLY) but offered not fix other than to take it for service. Luckly it is still under warranty. Anyone have this problem? Any suggestions on a fix before we have it serviced? |
New member Username: Estrada
Post Number: 1 Registered: Dec-05
| Posted on Monday, December 19, 2005 - 04:19 pm: |
I have had a Magnovox tv for several years but went in Demo Mode and I amunable to do anything with it. Any help |
| Posted on Monday, December 19, 2005 - 04:21 pm: |
My television went on Demo Mode dont know how to take it off. Can anyone help |
| Posted on Monday, December 19, 2005 - 08:31 pm: |
I am having same problem as below post. Any ideas ? We got a Magnavox 27" TV, Model #27MT3305/17, and it is turning on by itself. We called Magnavox and the CSR joked that the TV "was lonely" and "crying out for attention" (REALLY) but offered not fix other than to take it for service. Luckly it is still under warranty. Anyone have this problem? Any suggestions on a fix before we have it serviced? |
Post Number: 2 Registered: Dec-05
| Posted on Tuesday, December 20, 2005 - 12:41 pm: |
My tv is showing a black box in the middle of the tv there is sound dont know how to take off the black box dont have the manual |
| Posted on Wednesday, December 21, 2005 - 05:03 pm: |
I have a Magnavox TV given to me from Mother and suddenly things went haywire. I am using a Universal remote and suddenly it is asking for a PC Code. I am locked out of many channels. Can you possibly help me. |
| Posted on Friday, December 23, 2005 - 08:04 am: |
Also have a Magnavox, Model #27MT3305 which turns on by itself. |
Albert Nance Unregistered guest |
| Posted on Friday, December 23, 2005 - 03:27 pm: |
I have a Magnavox 46ish inch screen. Model FD4625 W103 made in aug. 95. The picture goes from color to black and white and back again. What could be the problem? |
New member Username: Davadd0809
| Posted on Monday, December 26, 2005 - 07:14 pm: |
I just purchased a 27" Magnavox Model #27MT3305/17 and ever time I turn it off using the remote control it automatically comes back on in 2 - 3 minutes. If I turn it off from the tv set it doesn't turn back on. This model does not have an auto-on/wake feature so I don't know why or how it turns it self back on. is this a defect or possible issue with the power surge strip that it's plugged into? I have a clock, lamp, and dvd player plugged into the same strip and have no issues with any of them; just the tv. I bought it from best buy and thought I would post this before returning the tv. |
TV Problem Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 04:10 am: |
Same problem here with 27" Magnavox Model #27MT3305/17 Turn it off and in a few minutes it turns itself back on. Anybody have suggestion? |
Richard Groves Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 10:04 am: |
I have a Magnavox 27MC4304 TV/VCR/DVD combo. Got it from Home Depot earlier this year. My huge problem with this unit is that it wont play any DVD's! It says the disk is not in the right format to play back...and it says this no matter what disk I put in there (region 1, 2 or region free or a music CD). Was unable to return it to the Home Depot as I had it too long which I think was BS, but there you go and haven't been able to find a solution for this yet. Any ideas from anyone? |
| Posted on Tuesday, December 27, 2005 - 04:28 pm: |
I bought a used Magnavox 25" tv that works great except EVERY time we turn it on it takes about 5 minutes for the picture to show up. The sound is fine but the screen stays black or snowy for about 5 min. and then just suddenly pops on normally! It's as if the tv had to warm up every time you turn it on! I have no idea why??? |
| Posted on Wednesday, December 28, 2005 - 09:17 pm: |
I have a magnavox lcd tv with dvd player built in to the side. After being on for a few minutes, an area appears asking for a password. No matter what I put in that box, it doesn't work. I tried shutting it off in the menu under clear but that is useless. Anyone have any ideas? |
| Posted on Wednesday, December 28, 2005 - 09:56 pm: |
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=555539#POST555539 |
hand some Unregistered guest |
| Posted on Tuesday, January 03, 2006 - 11:07 am: |
i have maganovex tv but my kid block some chanel.can you help me unlock. thank you so much |
| Posted on Wednesday, January 04, 2006 - 02:54 am: |
i have a magnavox 29inch tv and the colour is now a green tint over all the channels any help please the picture is unbearable |
| Posted on Thursday, January 05, 2006 - 12:58 pm: |
Have a Magnavox 32 inch. Has worked great. Get a picture but no sound. When the DVD-surround sound is on and a movie is playing it works, but to watch cable, no sound. Any ideas? |
| Posted on Thursday, January 05, 2006 - 03:05 pm: |
I Have a Magnavox TS3562 C101. its has been showing up white lines every once and a blue moon. but the other day when i went to turn it on and it seems like its going to turn on at first but then it just doesnt want to turn on. im not sure whats going on with it. i wanted to see if its just some simple part to replace? any thoughts. |
| Posted on Saturday, January 07, 2006 - 12:07 pm: |
I have a magnavox: 27MT3305/17 bought 2 weeks ago. For the past few days it keeps shutting itself off, every hour or so, in the beginning, and as the day progresses it does it every few minutes sometimes even seconds later after you turn it back on.. |
Gold Member Username: Samijubal
Post Number: 2074 Registered: Jul-04
| Posted on Saturday, January 07, 2006 - 12:11 pm: |
Return it and get a new one. Philips/Magnovox products are poor quality, buy a different brand. |
New member Username: Buddyboy
Temecula,
Ca
Us
Post Number: 1 Registered: Jan-06
| Posted on Saturday, January 07, 2006 - 01:36 pm: |
I purchased a Magnavox LCD flat screen (26MF605W/17) about a year ago. It has worked great until yesterday. Now it does not come on when I push the power button. The lights come on, but the screen doesn't come on. I tried unplugging for sevreral hours then plugging back in, but it still doesn't work. Any suggestions? |
| Posted on Wednesday, January 18, 2006 - 04:05 pm: |
I have a big screen Magnavox. On most channels the sound is just static, but on two channels the sound works fine. Any ideas |
| Posted on Wednesday, January 25, 2006 - 07:06 pm: |
I have a magnavox television. I can turn it on and in about an hour I get this black square box in the middle of the picture and it has some type on code at the top. The only way to make this box go away is to turn off the television and turn it back on again or mess with the volume button. Does any one else have a problem like this or similar, if so what do you do? |
New member Username: Arrowhed54
Post Number: 1 Registered: Feb-06
| Posted on Wednesday, February 01, 2006 - 06:16 pm: |
I have a magnavox 15 inch LCD tv model #15mf200v/37 and it will not turn on either by the remote or manually. I have checked the voltage at the on/off switch and there isn't any voltage but there is voltage to the main board. I measure 5V and 12V at different places. What could be wrong?? |
| Posted on Friday, February 17, 2006 - 03:28 am: |
I have a similar issue as one posted earlier. I have a 27" Magnavox TV...and after trying to use a Universal remote, the picture blanked out and text states that "PC Code Required for Channel ____. How can I get my picture back? |
| Posted on Monday, February 20, 2006 - 01:47 pm: |
I have two Magnavox 15MF050V/17 tv/monitors and each will power itself off after about a half hour of operation. I have contacted Magnavox about this and their only advise is to make certain that the power cord is plugged directly into an AC wall outlet and not into a power strip, UPS or extension cord, This all sounds sort of fishy to me. Anyone else having this problem? I am beginning to believe that Magnavox dumped a bunch of these units on an unsuspecting public and is hiding behind their pathetic 90 warranty. |
| Posted on Tuesday, February 21, 2006 - 09:07 pm: |
I have a 15inch Magnavox LCD TV model #15MF050V/17 the remote that came with it works sporadically so I bought a universal remote to replace it and can't get it to work or 3 others I tried also (different brands of remotes) any body else having this problem? |
| Posted on Thursday, March 02, 2006 - 06:06 pm: |
I have had the same problem but with model #15MF400T/37 I tried four different remotes. |
| Posted on Friday, March 03, 2006 - 06:49 pm: |
I have a Phillips Magnovox and the smartlock is on now. I do not know how it got on and do not know how to turn it off. Help. |
New member Username: Archietpal
Seattle,
WA
Post Number: 1 Registered: Apr-06
| Posted on Sunday, April 02, 2006 - 11:32 pm: |
I also having problem with my Magnavox 15mf050v/17 LCD TV, it turn off by itself after 30minutes & if you turn it on after, it turn off after maybe 5-10 minutes. |
New member Username: Perryshaw
| Posted on Monday, April 10, 2006 - 10:36 am: |
I also own a magnavox 15mf050v/17 LCD TV. At first I tried using it as a monitor, but the screen would turn itself off after 20 minutes, then when I turned it back on, it would last 10 minutes before turning off, then only 4-5 minutes. I thought that maybe I had not configured it properly to work with my computer, so I tried using it as just a TV. I had the same problem. If I don't use it for an three hours, then I can get a good 15 minutes of tv watching before it turns off, then 8 min, then only 4 minutes -- until off course I let i rest for three hours. This was my first foray into LCD, and I have to say I'm very dissappointed with Magnavox for selling such an obviously deficient product. Unfortunately for me, I was naive enough to believe that the 'turning-off' was my fault at first (as I mentioned, this was my first LCD TV experience, and I thought I was setting it up properly), by the time I realized the TV itself was to blame the 90-day warranty had expired. The people at Magnavox were not helpful at all. |
New member Username: Thomas_f
Santa Fe,
NM
| Posted on Tuesday, April 11, 2006 - 04:16 pm: |
MAGNIVOX GONE DARK! I have a new flat screen Magnivox. It's connected to a Comcast cable outlet. Two days ago there appeared a large dark shaded box covering most of the picture screen. The wierd thing is that it's only on certain channels including CNN. No matter what I do with the TV or the remote, it doesn't go away. The user manual is of no help. There is also some kind of indistinguishable icon in the upper right corner of the screen with an X through it, which may have something to do with the problem. Is this some kind of parental control?? Please help us clear up the screen. Thank you. |
New member Username: Magamadness
La ,
Ca
Ua
Post Number: 1 Registered: Jun-06
| Posted on Friday, June 16, 2006 - 01:34 pm: |
Same probelm with my Magnavox.. but it turns off.. just when I turn it on, it will stay on for maybe 10 seconds then flashes off . I have to change it on/off several times before i can get it to stay ON to watch. HELP! seems like this is a problem for a few of us Magnavox 27MT3305/17 |
New member Username: Siouxcity1sueyahoocom
| Posted on Thursday, June 22, 2006 - 12:03 pm: |
Have large console Model RK6020 Ak02 purchased in '91. Try to turn on and goes "psst" but never comes on. |
New member Username: Nec602004
Orlando,
Fl
Us
Post Number: 1 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 12:32 am: |
