Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > The incredible shrinking picture
Author Thread: The incredible shrinking picture
Username: Mcmclaug
This problem sound familiar to anyone? My 30" toshiba's picture is shrinking horizontally and is now almost only 4" high. Also, the bottom 1" is inverted. Is it a simple capacitor replacement or is the set shot and not worth fixing? In other words, would the repair cost be as much as a new tv? Any help would be great!
Username: Samijubal
Post Number: 1400
Sounds like something in the power supply/regulator circuit. Unless you have test equipment or can see a leaking capacitor, I don't know if you could fix it.
Username: Vindsl
Post Number: 233
Flyback transformer...
Username: Mcmclaug
No, I don't plan to fix myself, I was going to have to bring it to a repair shop. Just wondering if these possible ailments are worth my time and effore to fix or just buy a new approx $200 set? Thanks for the info :-)
Username: Samijubal
Post Number: 1404
Depends on how good the Toshiba is. For $200 all you can get is a piece of crap.
Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > The incredible shrinking picture [ « Previous ] [ Next » ]
