Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > RCA no picture, no sound
Author Thread: RCA no picture, no sound
Username: Marleyc22
Hi, I have an RCA tv/cable box/VCR/DVD connection that worked fine last night. This morning when i turn on the TV i get no picture and no sound. The cable box guide still works. Put a movie in the VCR and that worked great. Any ideas?
bobby ccity
The input for the cable box may be going bad. Is it going through an f-pin coax, or other cables? Try switching the cable to another input if it is through composite cables.
Username: Marleyc22
thanks bobby. all the cable cords are coax i think. they are the ones with the little pin in the middle.
i tried to hook up the cable directly to the tv and skip the cable box. which i get picture and sound but it only stays on what seems is channel 4...the numbers move up and down but the picture stays the same. who knows...just going to call someone i guess. thanks for you help.
Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > RCA no picture, no sound [ « Previous ] [ Next » ]
