Thread: This girlie needs help re: the Pansat 2500A |
New member Username: Lez
Toronto,
Ontario
Post Number: 1 Registered: Aug-05
| Posted on Wednesday, August 03, 2005 - 02:13 am: |
Hey guys, I've read most posts concerning the Pansat 2500A, and still haven't been able to figure out what's wrong. But I know absolutely nothing about satellites, recievers and such, so I could've stumbled across a solution and not known it. Anyway, when I check the signal strength, for most satellites the "Level" is between 75-90%, but absolutely nothing appears on the "Quality" bar, and of course, no channels appear. That's about it. Help is very much appreciated. |
| Posted on Wednesday, August 03, 2005 - 06:39 am: |
goto dsscentral.nett go to file archives, go to fta files |
quality Unregistered guest |
| Posted on Wednesday, August 03, 2005 - 07:28 am: |
turn your dish a little bit |
BoogyMan Unregistered guest |
| Posted on Wednesday, August 03, 2005 - 08:15 am: |
DO a scan? channel won't just appear b'coz you found the satellite. |
Toronto,
Ontario
Post Number: 2 Registered: Aug-05
| Posted on Wednesday, August 03, 2005 - 12:46 pm: |
I used to turn the dish before when this happened, but it no longer works. Same goes for scanning. |
Thrill 1951 Unregistered guest |
| Posted on Wednesday, August 03, 2005 - 03:54 pm: |
-"SHOW" Us all your girlie and we will show U all our dickeeeeeees |
| Posted on Wednesday, August 03, 2005 - 04:17 pm: |
Thrill1951 I think you just showed us you are a Dick! Now go play with yourself and grow up! What a bunch of immature retards there are here at this site!!!Why doesn't this sites moderators kick these children out??? |
| Posted on Wednesday, August 03, 2005 - 04:41 pm: |
The mods here are the imposters and making all the stupid posts...this is not your typical DSS forums..these forums are for 2 purposes..monitor Dss activities and any hacks or breakthroughs..bring $$$$ to Ecoustics and their sponsors..the mods here are informants and work for the FCC.. |
| Posted on Thursday, August 04, 2005 - 12:36 pm: |
Thanks for your reply LK, and for staying strong and helping us out here with questions! You are one of the only reasons I still visit this site! |
harlingen Unregistered guest |
| Posted on Thursday, August 04, 2005 - 12:41 pm: |
me too |
