Thread: Screen Replacement |
Big_Scrnr Unregistered guest |
| Posted on Wednesday, August 03, 2005 - 01:28 am: |
I accidently put a hole through the plastic and screen of our 52 inch Panasonic television tonight and I am wondering if you can replace the screen? The model number is PT51SX30CB. |
Bronze Member Username: Hd_fanatic
Boise,
ID
Post Number: 46 Registered: May-05
| Posted on Wednesday, August 03, 2005 - 01:36 am: |
Most screens are replaceable. I am not familiar with the model # you listed. How old is the set? If the set is over 7 years old, you may have difficulty finding a replacement screen. If you can find a replacement, anyone with decent mechanical abilities should be able to change it out with no problems. |
| Posted on Thursday, August 04, 2005 - 12:06 am: |
Yeah, I searched the net and couldent find much on that model. However I did find a site that used to carry screen replacements for them, but they do not ship them anymore due to damaged screens arriving. Thanks for the help |
Silver Member Username: Mr_lynch
Seattle,
WA
Post Number: 809 Registered: Sep-04
| Posted on Thursday, August 04, 2005 - 02:37 pm: |
Check out Best Buy. They work with a company that custom makes replacement screens. http://www.bestbuy.com/site/olspage.jsp?skuId=5405572&type=product&productCatego ryId=cat08097&id=1051806321569 |
