Thread: How To Manually Input New Keys |
| Posted on Tuesday, August 02, 2005 - 06:17 pm: |
Here Are Simple Step By Step Instructions For Updating The Keys For Your Stb: ================================================== Suggestion Courtesy Of Bandit13: How To Manually Enter Keys For Pansats: ------------------------------------------------ Menu button select Parental Controls 2nd PIN/enter 0000 Nagravision Select ~~~~~~~~~~~ ( top right, use R / L Arrow Buttons ) scroll down select key 0 scroll down enter ( new key ) ( The letter keys are shown on the screen by function key ). Check it carefully. scroll up select key 1 scroll down enter Keys ( Same letter keys as above - bottom of screen ) check it carefully. Hit and hold OK until it flashes ( red, bottom right ) on the screen. exit out and watch TV .. Suggestion Courtesy Of Wtm: For Those Using The Pansat To Fortec Bins ============================ Menu Right side volume button to channel edit down to codes 1668 or 1010 down to nagravision right side volume button to DN same as pansat except A-Sat B-Info C-Tv / Radio D-Upper Pause E-Audio F-Epg Suggestion Courtesy Of Frankott: How To Manually Enter Keys For Lifetime Ultras: ------------------------------------------------------- Click Menu on the remote Then side arrow to Channel Edit Then down to Code then Ok then 1668 or 1010 Then side arrow to turn code Off just to be safe Then down to Nagravision then OK Then side arrow to Dish Network You need to change the keys on two lines. In Provider Id it will be 00 // 01 Then down arrow to Key Number & Make change Then down arrow again to Key number & make change Then Hit Ok to save. Then Exit once Then side arrow once, then 1668 to turn code back ON Make sure your Key Code Function is On Your TV should work now after you exit out letter Codes ======== A - Sat B - Info or I C - Tv / Radio D - Pause E - Audio or ? F - Guide or Epg How To Set The Default Keys: =================== Click on Menu , then go to Channel Edit , then Code , then Ok put in 1010 or 1668 then the down arrow to Set Default Key and click OK then exit out. Suggestion Courtesy Of Dipper: How To Manually Enter Keys For Coolsats: ------------------------------------------------- Go to Channel 8282 Use the right arrow to scroll to 111 Nagravision ( Dish Network ) Enter the keys . Use the Info button for letters A-F . Press it once for A , twice for B , Etc . Exit Out & Save Changes & Watch TV Suggestion Courtesy Of Bandit13: How To Manually Enter Keys For Viewsats: -------------------------------------------------- Press Menu Button Installation Selection ( #3 ) Code Selection ( #7 ) Nagra Selection ( #3 ) Dish Network Always Leave The First Set Of Digits Alone ( 00 = First Row // 01 = Second Row ) There Should Only Be 8 Rows To Change For Active key If Needed ( A Total Of 16 Digits ) Change Keys If Neccesary On Active Key Or Where Necessary Press Exit And Press Ok To Save Changes Press Exit Button To Completely Exit Out Of Menu Options To Watch Tv . Suggestion Courtesy Of Yono: How To Manually Enter Keys For Ariza: --------------------------------------------- Press 1- Green button 2- Red button 3- Red button 4- Menu button 5- Press right arrow several times until you see nagravision 6- Now depend on the key that changed and it is active you must scroll down til proper key to be changed Example: On 06/09/05 ECM key 01 is active. Scroll down to provider 000101 01 key line and enter xx xx xx xx xx xx xx xx (enter number with your # button in your remote and for letter follow code definition button on your TV screen) 7- Press OK for 5 seconds. 8- Exit,exit........... 9- Enjoy DN active provider in ariza flash is 0101. so edit keys in 000101 lines DN key 00 is in 3rd line from top to botton Key 01 is in 4th line Suggestion Courtesy Of Yono: How To Manually Enter Keys For Digiwave: ------------------------------------------------- 1- Press MENU 2- Scroll down to System Setting. 3- Press OK. If you see a red dot in the botton/left of your screen, go to step 5 4- Enter number 1004. A red dot will come out at ur bottom left. YOU DO NOT NEED TO DO THIS STEP w/ lastest bins. 5- Press red button (audio). 6- Press right arrow until NAGRA appears in the first line. 7- Down arrow up to Provider and right arrow up to 0001. 8-Now scroll down to first key line and press OK. scroll to the letters and number and enter Key 00. Get keys from Maestra or another site or using a key grabber program such as keymaster or Getkeys. 9-Scroll down to second key line, press ok. and enter key 01 10- Scroll To Save Key and 11- Press OK. 12- Exit and Enjoy |
| Posted on Tuesday, August 02, 2005 - 06:29 pm: |
For the BB (BlackBird), U must change the bin to input the new keys...here's how.. Do this. Inputed the keys in the "key_version.txt" located in the RMO folder. Look at the format of the current "key_version.txt" file and input the numbers the same way (That means include the dashes). Where you see "new version:", you can use any four digits you like. Generally this would be the date (such as new version:0723) Then all you need to do is execute Ultimate.exe. You have your new bin. Hope you know how to do the following. Load the bin into your receiver. If you have a channel list load it or scan your channels in.
