Thread: PICTURE FREEZING ????? |
honeybun Unregistered guest |
| Posted on Friday, July 29, 2005 - 12:48 pm: |
THIS A COMMON PROBLEM I HAD FOR 3 WEEKS UNTIL I READ THIS....... LK Posted on Friday, July 29, 2005 - 08:48 am: --------------------------------------------------These are the ONLY correct keys! (C1-NOT C0)...when using an autoroll bin,the autoroll will sometimes INCORRECTLY roll the first 2 digits (Example C1 to C0)and then cause picture freezing intermittently..this is corrected by inputting the CORRECT keys as listed below!...just manually change the first 2 digits back to what they should be C1.. DISHNET KEYS Current 07-28-05 5:45pm EST Key0: C1 AE 0A 78 65 47 BB E4 ** Active Key1: E9 FD 53 DE B5 37 FC 44 |
| Posted on Friday, July 29, 2005 - 01:25 pm: |
I'll be darn....... I couldn't figure it out. Thamks guys !!! |
Go Bears Unregistered guest |
| Posted on Friday, July 29, 2005 - 04:50 pm: |
thank-you thank-you thank-you |
New member Username: Jodona
Post Number: 1 Registered: Jul-05
| Posted on Friday, July 29, 2005 - 05:01 pm: |
hola a cavo de comprar un sistema de pansat2700 pero no se como conestar ayudemen por favor |
| Posted on Friday, July 29, 2005 - 05:14 pm: |
do you have to reset pansat after you manually change the wrong keys? |
Moriarty Unregistered guest |
| Posted on Friday, July 29, 2005 - 06:12 pm: |
wow...it worked ! Thankx !! |
| Posted on Friday, July 29, 2005 - 07:48 pm: |
thanks |
| Posted on Friday, July 29, 2005 - 09:17 pm: |
DISHNET KEYS Current 07-29-05 5:20pm EST Key0: C1 AE 0A 78 65 47 BB E4 Key1: BC B0 95 AC 66 E9 A7 42 ** Active and yes U should do a reboot/reset (BACK of receiver,power off,wait 1 minute,power on) AFTER a key change or if U EVER have any problems.. |
jazmine Unregistered guest |
| Posted on Saturday, July 30, 2005 - 01:02 am: |
thanks LK |
| Posted on Saturday, July 30, 2005 - 11:28 am: |
are there autorolls that dont have this problem(wrong fist digits)? for pansat2500 and if somebody knows what is the that autoroll or where can I look for it? intallation is no prob. thanks |
