Thread: Help - Broken S-Video Pin stuck in receiver |
New member Username: Av_impaired
Post Number: 1 Registered: Jul-05
| Posted on Tuesday, July 26, 2005 - 12:35 pm: |
Long story short - I broke off a pin from the S-Video cable and it is stuck inside of my DirectTV/Tivo unit. If I go buy another S-Video cable, I won't be able to plug it in, b/c the #$%#@#& pin from the cable is stuck in its respective S-Video hole. The pin is not protruding from the hole even a little bit. Obviously, this is a very tiny pin, stuck in a very tiny hole (no jokes, please . . . this is not a metaphor). Any ideas on how to get it out? Is it possible? Do I need to buy a new unit? Thanks. |
| Posted on Tuesday, July 26, 2005 - 02:59 pm: |
Take off the cover, and try pushing it out from the other side with a needle,worse case replace it...rat shack. |
