Home > Message Board > Home Video > Direct View TVs > Archive through December 28, 2005 > Magnavox RH4558 - Coax Input not working
Author Thread: Magnavox RH4558 - Coax Input not working
Jonathan S
I have received a Magnavox RH4558 that powers up and works fine with the RCA Video and Audio inputs. But, it will not accept a signal on the coax input.
I have looked any obvious loose connections, but have not tested any voltages because I haven't found any technician data.
Jonathan S
Further testing revealed that the TV could receive RF input only on analog cable channel 24 when the TV tuner was set on channel 10.
I don't believe a tuner in a set this old is worth fixing.
Username: Dmwiley
Post Number: 948
Nice to know. Thank you very much.
Home > Message Board > Home Video > Direct View TVs > Archive through December 28, 2005 > Magnavox RH4558 - Coax Input not working [ « Previous ] [ Next » ]
