Home > Message Board > Home Video > Satellite TV > Archive through August 08, 2005 > Now that BEV is gone what are you poi...
Author Thread: Now that BEV is gone what are you pointing at ???(FTA)
point me
i still have 110 and 119 but now that 91 is done what bird should i aim it at? Is there anything else worth while up there?
compost
i think you can pick up T5....not sure of the channels
chicago
go to www.lyngsat.com and check out the different satellites and channels on each yourself...then make own decisions.
Home > Message Board > Home Video > Satellite TV > Archive through August 08, 2005 > Now that BEV is gone what are you poi... [ « Previous ] [ Next » ]
