Thread: Samsung 4674w screen loose and making noise |
Bronze Member Username: Russtri
Post Number: 17 Registered: Mar-05
| Posted on Monday, July 18, 2005 - 03:04 pm: |
This weekend I heard a weird vibration noise when I had my Sammy volume up a little above normal. I noticed that the screen was making the noise. I am able to push the screen in at the top middle and it pushes in just slightly and rattles against the cabinet. Is this normal? |
Silver Member Username: Fyi
Dallas,
Texas
Post Number: 129 Registered: May-05
| Posted on Monday, July 18, 2005 - 05:03 pm: |
Something else is causing the set to vibrate. Sounds like bass tones since the volume was up. |
Post Number: 18 Registered: Mar-05
| Posted on Tuesday, July 19, 2005 - 11:01 am: |
Your right the volume was up but not rock concert high. I have a extended warranty on the set should this be something that is fixed. It is kind of annoying!!!1 |
Dallas,
Texas
Post Number: 135 Registered: May-05
| Posted on Tuesday, July 19, 2005 - 01:04 pm: |
Yea, give them a call! 1-800-SAMSUNG prompts are 2 then 1 then 3 then 1 They should take care of that.
