Thread: Are HP Projectors any good? (VP6320) |
New member Username: Saaketham
Post Number: 2 Registered: Jul-05
| Posted on Tuesday, July 12, 2005 - 12:13 pm: |
I wanted a reasonably priced projector as a temporary solution for large-screen movies/DVDs/games/gaming. I guess the hottest, reasonably priced projector for HT is the Panasonic ET-LAE700. But, its a bit over my budget. How about HP's VP6300 projector lineup? It doesn't have DVI or Y, Pb, Pr inputs, but the VP6320 specs looks awesome, otherwise. - Resolution = XGA (1042 x 768) - Brightness = 2000 ANSI lumens - Contrast Ratio = 2500:1 - Lamp life = 4000 hours !!! - Connections = VGA, RCA, S-Video Any suggestions, speculation about the quality? Thanks a lot in advance, folks. Anil |
Post Number: 6 Registered: Jul-05
| Posted on Tuesday, July 12, 2005 - 06:30 pm: |
The specs on the 6320 on several sites mentions it has DVI Input. But, on HP's spec sheet PDF, it lists Output: DIV-D, but DVI is not mentioned in the Inputs. Wonder what the deal is! |
