Home > Message Board > Home Video > DVD Recorders > Archive through August 04, 2005 > Sylvania SSR90V4
Author Thread: Sylvania SSR90V4
Username: Ejcc27
Chipley, FL
I cannot find the link for this forum, so I will post it new. I was very skeptical about this unit after I bought it, there was so much bad feedback. When I finally used it, I did run into the same problems everyone else had, so I called their tech support. They have a software upgrade they will mail that fixes (apparently) everything. Call 800-605-8453 and you'll need your model number
I have the same DVD recorder and my problem is protected DVD. How can I record DVD to DVD? I get "copyright protected" message all the time
Michael Herz
You can use following link to get all required information on your issue
http://www.xdimax.com/dvd/dvdredpro.html
I have the same one and it works fine.
Home > Message Board > Home Video > DVD Recorders > Archive through August 04, 2005 > Sylvania SSR90V4 [ « Previous ] [ Next » ]
