Home > Message Board > Home Video > TV Basics > Archive through October 13, 2004 > Sony 42'' grand wega split screen pro...
Author Thread: Sony 42'' grand wega split screen problem
Calvin
I bought this TV last December and I just notice the following when I use the split screen feature to view both cable / DVD. For some reason in split screen mode, if I try to change the right screen to from VIDEO 4 to 5(DVD with component cable), it just jumps back to my cable channel. But if I use the left screen, it works fine for DVD. Does it happen to anyone? Or there is something wrong with my set? Please advise
Only the Left Split screen will display the inputs 5+6. Those are the component IN inputs. Therefore you can display only 1 component input in split screen.
It's in the manual. :-)
I bought a Sony Wega KF50XBR800 last year and it is already experiencing a problem--the projection lamp turns itself on and off continuously. Does anyone know what would cause that and/or the part that needs to be replaced? Thanks
Username: Vindsl
auntmeel: There is a known problem with the lamp housings on some Sony Wega's - mostly ones made from late 2003 to early 2004. If the housing is loose the lamp will fail from a poor connection. So, make sure it is secure or changed out.
Advise please. I have the Wega 42". Is the blank screen of this model light grey and not black??
same here
mobile phone accessories china
Username: Mhj338
Miami, Florida
Miami-Dade
My 42" Wega blank screen is light grey. I read somewhere that this is one of the minuses.
Home > Message Board > Home Video > TV Basics > Archive through October 13, 2004 > Sony 42'' grand wega split screen pro... [ « Previous ] [ Next » ]
