Home > Message Board > Home Video > Rear Projection TVs > Archive through July 12, 2005 > Samsung DLP HL-R 4667W or HL-R 4677W
Author Thread: Samsung DLP HL-R 4667W or HL-R 4677W
Username: Chadnew
Can someone tell me why the 77 is more expensive? The 67 seems to have a lighter weight and more options ie: PC hookup. I have been told the 77 has a new generation chip but I can not find that info anywhere. I did a compare on Sammy's site and did not find a reason to buy the 77 over the 67.
Username: Emkmd
Post Number: 82
Chad,
The 77 models use a larger (0.8 vs 0.55 inch)higher end chip, I think the same one from last years 74 models. The 67 chip is smaller but uses a faster color wheel. The 67s also have a higher contrast ratio.
Check the following links:
http://product.samsung.com/SamsungUSA/PRODUCT/20050421/hlr5677.pdf
http://product.samsung.com/SamsungUSA/PRODUCT/20050504/HLR4266W4667W5067W5667W61 67W_3.PDF
-E
I get a screen door effect with the 4667 obviously no lines involved but looking at whites and some other colors it jumps out at me. I do not see them with the 4677.
Username: Fyi
Dallas, Texas
Post Number: 81
Anon,
You may be seeing something, like, as you described before, a fuzzyness or something, but it's not "screen door effect".
SDE is a grid pattern typical of wide pixel spacing in larger LCD displays and is non-existant in any DLP. You can put your nose on a DLP screen and not see between individual pixels.
Eric & Chad,
All "R" models have improved chips over "P" models. While they are of similar size they have faster mirror switching capabilities.
The R xx67 series has a new 5th gen light engine that concentrates more lamp light on the chip resulting in higher contrast.
The R xx77 series is still using the 4th gen light engine and contrast levels have remained the same.
Username: Chadnew
FYI and Eric thank you for the info. From the information I have gathered here would it be safe to say to buy the less expensive R4667 over the R4677? The 77 has lower contrast and older light engine.
I realize that you do not want to put a DLP up high, although I do not have a choice with the way my house is set up. Has anyone built in a 5 to 7% angle into the TV platform on their entertainment center to angle the screen down towards the viewers, and how did that work for you?
Username: Fyi
Dallas, Texas
Post Number: 82
The HL-R 5067W was my choice since I have no cabinet restrictions and my viewing distances are 8-10 feet. I like the floating screen design too. Mine is up higher than I sit. I tilted it down using two small paperback books under the back edges. That worked out perfectly for me. I have side seating out to 65 degrees on both sides and the picture looks the same as center viewing after matching up the vertical angle.
Home > Message Board > Home Video > Rear Projection TVs > Archive through July 12, 2005 > Samsung DLP HL-R 4667W or HL-R 4677W [ « Previous ] [ Next » ]
