Home > Message Board > Home Video > Projectors > Archive through October 31, 2005 > In Focus 7210 Projector hook up
Author Thread: In Focus 7210 Projector hook up
8118denon
hi, I am looking for an Infocus projector to run with denon DVD player and HTPC (home theatre PC). but there are couples of question i need help.
1. what is the best video connection. The 7210 has a M1 slot, dvd player got HDMI and my HTPC has DVI, how should i connect these 3 devices to get the best pic. Do i need to buy an AV receiver with HDMI and DVI input, and HDMI out? This is what i have in mind, connect DVD via HDMI to receiver, HTPC via DVI to receiver, and HDMI output from receiver to projector? works? or any other better way?
if i connect diectly from DVD and PC to projector, i have to connect the dvd via HDMI to M1 and component from PC to projector (i will need a DVI to component adpater)? is there any adapter or Y spilter for M1 that allow me to connect both devices to same M1 slot?
my another concern is, how long can i run the HDMI cable or the DVI cable before degration of image occurs?
I am hoping to view some 1080P movie using my HTPC, i understand if i connect my HTPC to projector via component, i am not able to have 1080P resolution, correct me if I am wrong.
Thanks
Username: Ziggyzoggyoioi
Outside Philadelphia, PA
Post Number: 34
No matter what you do, you cannot have 1080p resolution. The 7210 is a native 1280x720 projector.
Username: Saaketham
Quoting from
http://www.bluejeanscable.com/articles/dvihdmicomponent.htm
"In practice, it's very hard to say when a DVI or HDMI signal will fail. We have found well-made DVI cables to be quite reliable up to 50 feet, but HDMI cable, with its smaller profile, is a bit more of a puzzle. Because the ability to reconstitute the bitstream varies depending on the quality of the circuitry in the source and display devices, it's not uncommon for a cable to work fine at 30, 40, or 50 feet on one source/display combination, and not work at all on another."
Home > Message Board > Home Video > Projectors > Archive through October 31, 2005 > In Focus 7210 Projector hook up [ « Previous ] [ Next » ]
