Thread: Hookup cable box to DVD recorder and Vcr |
New member Username: Coldbeer65
Streamwood,
Illinois
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 27, 2005 - 12:18 pm: |
Hi everyone.. New guy here. Just want to hook up an inexpensice DVD recorder and VCR. My tv needs that adaper (Modulator) for out ( red-white-yellow) Currently have a cable box for HBO.. All I want to do is play a DVD, copy a DVD, & copy a VHS to DVD. Like to possibly copy a football game from tv say to VCR. I am not very smart when it come to this new technology as I am 70 years of age. Sure would appreciate any help.. Not looking for super this or digital that.. Located in Streamwood, Illinois.. E_Mail address: bobs-email@excite.com
Gold Member Username: Samijubal
Post Number: 1239 Registered: Jul-04
| Posted on Monday, June 27, 2005 - 02:09 pm: |
Connect the VCR to the DVD with RCA cables and set the recorder on whatever input you used. If the cable box has RCA outputs, connect it the same way, if not use coax. You will have to select the input you used for cable recording too. Connect the coax out of the box straight to the modulator if the box has RCAs, if not connect to the recorder and the recorder to the modulator. I'd suggest just using the DVD recorder for recording, not the VCR. DVDs are cheaper than VHS and the picture quality is far better. With your TV it would be easier to not have both set up for recording. |
phart buster Unregistered guest |
| Posted on Tuesday, June 28, 2005 - 07:57 am: |
Just hang up dummy. |
| Posted on Tuesday, June 28, 2005 - 07:59 am: |
Oops. Wrong thread. |
New member Username: Jtadams45
Sidney,
Oh
| Posted on Wednesday, June 29, 2005 - 09:36 am: |
I HAVE A DVD RECORDER VCR COMBO RECORDER AND ALSO PLAYS I'VE TRIED EVERY HOOK UP I CAN AND I CANNOT GET IT TO SETUP OR FORMAT IAM HOOKING UP THROUGH SATELLITE BOX TO TV ,CAN ANYONE HELP ME ? |
| Posted on Friday, July 08, 2005 - 01:05 pm: |
I have a Comcast DVR and I'm trying to hook up a DVD Recorder and VHS. I'm having problems getting the DVD Recorder to work. A big problem is with the DVR from Comcast, there is only one spot to put the cable in from wall. There isn't an output. I have already spent hours and hours and still cannot figure it out. Has anyone run into this problem with the Comcast DVR??? |
Post Number: 1282 Registered: Jul-04
| Posted on Friday, July 08, 2005 - 01:09 pm: |
It has to have an output or you wouldn't be able to watch it. |
joelh17 Unregistered guest |
| Posted on Monday, July 18, 2005 - 04:30 pm: |
you have rca outputs and component outputs on the back of a dual tuner motorolla cable box. |
New member Username: Lrampone
Bradenton,
FL
Post Number: 1 Registered: Aug-05
| Posted on Sunday, August 28, 2005 - 12:03 pm: |
Hi. Going crazy trying to hook up my HD Ready TV with cable HDDVR to new DVDR/VCR combo we just bought. Cable guy had used component cables (r, bl, gr) between the cable dvr and tv. How do I put the dvdr/vcr combo in between the box and tv? According to all diagrams I have seen, I don't see any extra component cables used. And can't find how to use s-video cables either. I have two s-video cables and only one set of component cables. Please help... and can you also email to lrampone@tampabay.rr.com? Thanks! |
Bradenton,
FL
Post Number: 2 Registered: Aug-05
| Posted on Sunday, August 28, 2005 - 12:17 pm: |
of course, I also have plenty coaxial and rca cables...
New member Username: Joanie
Warminster,
PA
Post Number: 1 Registered: Sep-05
| Posted on Monday, September 05, 2005 - 09:34 pm: |
Hi I've been working on this little project for days. I have my tv and dvd/vcr already hooked up and then I bought a dvd recorder now the problems begin.....I have it hooked up to record from my tv but can not figure out how to hook dvd recorder to record from vcr? There are options to record from A/V1-front A/V2-rear, S-Video and DV. I'm really new to all this stuff. Thanks do appreciate your time for helping me. |
Post Number: 1576 Registered: Jul-04
| Posted on Monday, September 05, 2005 - 10:10 pm: |
Connect RCA cables from VCR to DVD and set the DVD on whatever input you used. |
Warminster,
PA
Post Number: 2 Registered: Sep-05
| Posted on Saturday, September 10, 2005 - 04:15 pm: |
RCA cables they are the red/white/yellow cables? I have done that it only lets me record off my tv. I don't know what A/v 1 or A/v 2 are they the connections either front or back? when I connect the cable do the cables go in the dvd input or output? |
New member Username: Katnap
Edmonton,
London
England
| Posted on Saturday, September 10, 2005 - 05:22 pm: |
Hi Good People, Would appreciate any help for the following.I have a Alba DVD player & a Philips DVD recorder,is it possible to make them region free,so i can play/record Amercian etc DVDs. Any help would be most grateful,many thanks. |
