Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > Wharfedale M2126 TV
Author Thread: Wharfedale M2126 TV
Username: Geoff_stevenson
The only display that I receive from this TV is a Blue screen with a request for a 3 digit key display to be entered. This fault has followed a power surge. The manual does not give any guidance on this!and any number of 3 digit combinations have been unsuccesful
Has anyone got a clue on how I can bypass this screen to gain access to the programmes?
I have the same problem any help would be most appreciated!!!
Same problem here, did anyone get theirs fixed?
Janice McLeod
I also have this problem. I thought it was because my son was fiddling with the remote. Did anyone manage to resolve this problem and if so would you be kind enough to share the info.Thanks.
I have fixed the problem more by luck than anything else. press the P P button on the remote control rapidly. this should give you access to the blue screen lock command. switch the blue screen lock off. This removes the blue screen and the picture is restored.Good Luck!
i need the Remote for my tv can you help its a Wharfedale m2126 21" tv
Mark Munro
Got through to Argos support, and it is actually pressing the p p button 3 times, regardless of speed.
But I can understand the frustration that drove you to rapid button pressing.
And well done for discovering it at all.
Username: Worldsbestmummy
I need to tune a program in on my wharfedale tv but I have lost the manual can anyone help?
michellinap
I fixed mine getting the unlocking password from argos help line.
michellinap
Username: Paulg
I have a Wharfedale 150 tv and remote but no instruction book. Does anyone know how I can tune the channels in??
Username: Mondrak
Hawkinge, Kent
UK
Press menu twice and then you will get the option Auto Tune and Manual Tune. Then your away
Username: Paulg
Thanks for you reply Diane and Alastair but neither worked. I know the TV works because I tried it at the friends I got it from. (They dont know how it works). The channel change worked ok but the picture was not tuned in correctly. When I got it home and swithched on it showed an untuned screen and at the top were the words HEAT RUN . What is that? There were no channels, not even fuzzy pictures. I know the remote works, not only as I have new batteries but the video works fine. Pressing Menu has no effect. I may well have to take it for repair or get another TV.
kevin connell
does anyone know how to change the tuning from uhf to vhf. this is driving me nuts and any suggestions would be great.
Home > Message Board > Home Video > TV Basics > Archive through September 12, 2005 > Wharfedale M2126 TV [ « Previous ] [ Next » ]
