Thread: HELP - Sony SAT HD300 DVI won't work |
New member Username: Roscoe
Post Number: 3 Registered: Mar-04
| Posted on Saturday, March 13, 2004 - 01:11 pm: |
Jsut bought the reciever to connect with my Samsung DLP TV. Selecting DVI shows "Searching for Signal". Had to use the component cables to see a picture. Ideas? Roscoe |
Allen Endres Unregistered guest |
| Posted on Tuesday, March 16, 2004 - 02:24 am: |
Roscoe, you need to press the tv/video button on the remote, then scroll down the list of connected/not connected to the DVI mode. It should read connected. Press the joy stick button. this will active the DVI mode. If you have a universal remote that will handle all your devices, you can program this procedure from the Samsung remote to one button on the universal remote, makeing it much easier. Hope this gets you going. Allen |
Bronze Member Username: Roscoe
Post Number: 12 Registered: Mar-04
| Posted on Tuesday, March 30, 2004 - 10:34 pm: |
That I knew...the silly detail I missed was the switch on the back of the player to select Component or DVI output. |
