Thread: Need help with VHS/DVD recorder combo |
New member Username: Hugs_tn
TN
Post Number: 1 Registered: Jun-05
| Posted on Wednesday, June 22, 2005 - 02:20 pm: |
Hello everyone, I am trying to convert all of my VHS tapes to DVD and was discouraged when finding that a lot of them are Macrovisioned. I read a posting today that said you can not copy protected VHS with a combo unit. Is that true? If so, I am really discouraged. I read several other posts on this site claiming that a stabilizer will work but I didn't know if that includes VHS/DVD combo machines or not. I also read another posting on another site that said something about using an ancient VCR to bypass the encryption but I don't know if I can do that with a combo machine. I have an old VCR that I can use if anyone has any suggestions... Please help if you have any info for me. I would greatly appreciate it. |
Gold Member Username: Samijubal
Post Number: 1199 Registered: Jul-04
| Posted on Wednesday, June 22, 2005 - 02:29 pm: |
You can use the old VCR with a stabilizer in between that and the combo. |
Unregistered guest |
| Posted on Friday, July 08, 2005 - 07:48 am: |
I have the LG RC1000 DVD/VCR both dvd recorder and a vcr recorder combi. How can I copy an unprotected dvd to the dvd recorder of the combi? In other words how do I hook up a dvd player to the combi to copy the dvd to dvd? Thanks Also what is a stabilizer in between the old vcr and the combo in the above question? |
Silver Member Username: Dmwiley
Post Number: 895 Registered: Feb-05
| Posted on Friday, July 08, 2005 - 08:54 am: |
David, apparently you need to define "between" for Maryb. |
Post Number: 1281 Registered: Jul-04
| Posted on Friday, July 08, 2005 - 10:59 am: |
If the DVD isn't copy protected, just connect the player to the recorder with an s-video cable or RCA cables and set the recorder on whatever input you used. If you use an s-video cable, the best way, you need RCAs for audio too. |
