Thread: I got $5k to Spend what 60" do you recommend |
| Posted on Tuesday, June 21, 2005 - 08:28 am: |
Please help me in deciding my home theater fate. Currently I'm deciding between the 60" XBR and the 61" Sammy. Your thoughts. |
Bronze Member Username: Klaus
Holiday,
FL
Post Number: 73 Registered: May-05
| Posted on Tuesday, June 21, 2005 - 08:36 am: |
Both are good , but for close viewing the Sammy is a bit better. Also you should check out the JVC DILA. It has a picture that is close to DLP sharpness, with LCD like color depth. Of all the sets as with CRTs before, personal preference should always be the deciding factor. Haunt the stores, watch every set for a while with different types of inputs. Bring a favorite DVD if possible. If they won't play it, find a store that will! |
| Posted on Thursday, June 23, 2005 - 05:40 pm: |
2 - 30" flat screen TVs |
